Help please
runninonthebuck
Reg. Apr 2011
Posted 2011-04-30 3:29 PM (#133694)
Subject: Help please
Just bought a sundowner LQ trailer. It has a tank with a spigot under the mangers for the horse water.
How in the heck do these work? I drove a long way for this trailer and this was the one thing I forgot to ask about.
Posted 2011-04-30 10:54 PM (#133700 - in reply to #133694)
Subject: RE: Help please
1000500100100100252525
could you post a picture of the water tank?
hogtownboss
Posted 2011-04-30 11:28 PM (#133702 - in reply to #133694)
10001001001002525
Originally written by runninonthebuck on 2011-04-30 3:29 PM
I have the same type set up and main power has to be on inside the trailer, then mine has another rocker switch inside the manger by the little water pump.  With the main power on, I just flip the rocker switch then turn on the faucet.
Does yours have a pump mounted above the tank????  If so, follow the wires and it will be hooked to a switch.
runninonthebuck
Reg. Apr 2011
Posted 2011-05-01 11:56 AM (#133714 - in reply to #133694)
Okay I don't see where the pump for it is, there is a rocker switch for it. So turn all the power on inside then turn on the rocker and it should work.
I shall go try that, Thank you!
