jack falls
mwatson
Reg. Mar 2011
Posted 2011-03-22 8:20 AM (#131972)
Subject: jack falls
I have a stock trailer and the jack will fall down going down the road. How do i fix this.
Posted 2011-03-22 10:03 AM (#131977 - in reply to #131972)
Subject: RE: jack falls
I realize this is your 1st post and I welcome you to the website.  But we are not magical in being able to second guess your problems. You need to give us a little more info or a picture.
Describe what normally holds the jack up.  What part is failing?
Is a pin falling out, is a spring falling to hold up the foot.   Is it a Gooseneck trailer or a bumper pull. Just what kind of jack is it?
jim bob
Reg. Jan 2008
Posted 2011-03-22 10:12 AM (#131979 - in reply to #131972)
Weld a u bolt or something like that to the foot of the jack, and than attach a long and sturdy spring to either a bracket fastened to the area next to the jack mounts.  If you can picture this, the spring would be parallel with the jack; but it would keep it from dropping while in transit.  I presume you have a drop leg style jack, and I'm guessing that maybe the bottom part may be bent a little bit, whereby the spring pin won't quite hold it with the vibration from the road.
mwatson
Reg. Mar 2011
Posted 2011-03-22 3:03 PM (#131986 - in reply to #131972)
THANKS ALL AND YOU ARE RIGHT I DIDNT GIVE ENOUGH INFO. IT IS A GOOSE NECK AND IT HAS A CENTER JACK AND THE INSIDE PART AND THE FOOT TAHT LETS DOWN FALL GOING DOWN THE ROAD. THANKS FOR THE IDEAL ABOUT THE SPRING THAT WILL WORK. I TOOK A CHANCE AND TORE THE JACK APART AND FOUND OUT THAT IT WAS BROKEN SO SPING WILL WORK         THANKS ALL AND SORRY ABOUT NOT ENOUGH INFO.
Posted 2011-03-22 9:37 PM (#131995 - in reply to #131972)
1000500100100100252525
welcome to the site there is a lot of information on this site , a bungee cord may work to keep the foot up. I would also check to make sure that the crank works well and it is not on the last leg
