Fender Trim
Kesta
Posted 2011-03-11 4:56 PM (#131539)
Subject: Fender Trim
The black rubber trim on my fenders draws up in cold weather and comes off in places and hangs by the tires.  In warmer weather I can get it to fit and stay on.  I've tried an adhesive, but the contraction of the rubber in cold weather is stronger than the adhesive used (can't remember what brand).
Any suggestions for fixing this problem?  Of should I switch it out for a better quality trim.  If so, what brand is recommended and where can I get it?
Spin Doctor
Reg. Nov 2008
Posted 2011-03-12 8:01 AM (#131559 - in reply to #131539)
Subject: RE: Fender Trim
Replacing it with new would sure help for a few years. I would talk to the local dealer or call the factory to find the right kind.
If you don't want to replace it, you could put a small pop rivet every few feet riveting the trim to the fender. We did this on our old Hart trailer as I didn't want to spend the $ to replace it. That seemed to help.
Good luck!
Posted 2011-03-12 8:30 AM (#131564 - in reply to #131539)
Here's a couple of sources for new trim
http://www.trimlok.com/regular_trim.aspx
http://cgi.ebay.com/ebaymotors/Trim-Lok-X2003-Rubber-Edge-Trim-1-8-I-D-8-feet-/190511363687?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c5b5cb667
Bells
Reg. Jun 2007
Posted 2011-03-12 8:38 AM (#131565 - in reply to #131539)
I replaced a bit of my trim last year and secured the new trim and the old trim using small paper clips - the alligator type.  I put them in place and then remove the silver handles.  They have worked really well keeping every thing in place.
Kesta
Posted 2011-03-12 12:54 PM (#131567 - in reply to #131539)
Thanks for the suggestions everyone.  I appreciate it.
River19
Reg. Mar 2011
Posted 2011-03-21 11:38 AM (#131923 - in reply to #131539)
Does this trim flex well with curves?
I have to redo the trim around the roofline on my Cotner trailer and I'm looking for a solution....in addition to needing to rebuild an escape door.....should be fun !!!
Thanks
Steve
Posted 2011-03-21 1:33 PM (#131928 - in reply to #131539)
A tiny pop-rivet at each end and a couple along the center will help hold them in place.
linemansteve
Reg. Sep 2010
Posted 2011-03-22 6:05 AM (#131967 - in reply to #131539)
Try --horsetraileraccessorystore.com  They are in Oregon. They have a ton of stuff and are great people. I ordered 24 ft of fender trim to my door for around 38 dollars. Thanks Steve
River19
Reg. Mar 2011
Posted 2011-03-22 6:26 AM (#131968 - in reply to #131539)
Thanks for the information guys; I have had that place bookmarked for a while now, good stuff, it's also nice to hear they are good people too.
Although I'm a little aprehensive to pop a rivet through the figerglass top to hold the roof trim around the perimeter, what kind of glue is normally used?
Posted 2011-03-22 9:22 AM (#131975 - in reply to #131968)
Originally written by River19 on 2011-03-22 7:26 AM
I was talking about a pop rivet to hold the trim onto the aluminum fender as the OP mentioned.
Edited by retento 2011-03-22 9:24 AM
Linda Y
Reg. May 2007
Posted 2011-03-24 10:24 AM (#132050 - in reply to #131539)
10010010025
In this same vein, a friend is having this same problem. The other day she asked what I thought of spraying the entire fender with spray-on bedliner. Personally, I wouldn't like it and think that it may chip and peel if not done 100% right. Then there would be a REAL mess.
What do you all think??
Posted 2011-03-24 10:44 AM (#132054 - in reply to #131539)
An alternative to the plastic trim is to mask a half inch space around the edge of the fender and paint it with one of the cold applied bed liner materials. It looks just like the mouldings, wears well and is easily repaired if damaged.
Linda Y
Reg. May 2007
Posted 2011-03-24 12:00 PM (#132063 - in reply to #131539)
10010010025
Thanks, Gard. Since mine were sagging, I just took them off. May look into that for my own!
