Location: newhall, california | I am looking for a new 2 horse trailer for my daughter. I have been told fiberglass roofs deteriorate(sun exposure) but steel roofs rust. Which would be a better choice for longevity?? |
   Location: Arkansas | I have had a 6 horse with a solid fiberglass roof, and 1 two horse TB trailer with an all fiberglass roof, and currently own a 2 horse that the nose cap all across the front and overhead of the head area is fiberglass. It is a 97 model and shows no deterioration at all. Our 97 20' gooseneck stock trailer is showing rust on the roof, top, and underneath......same climate and conditions. If you were to fiberglass wax your fiberglass roof once a year it should hold up really well. None of our fiberglass roofs ever had any issues at all.........all of our steel ones eventually did. |
Location: newhall, california | Thanks for the input...we live in California and the trailer will most likely be stored in desert area. Temps in the 100's are common in summer months and the area does get snow at times in the winter. What is your climate like? |
   Location: Arkansas | Some summer months 100's, high humidity, some winter temps in the single digits....lots of summer sun, not a lot of snow |
       Location: western PA | The resins used in the fiberglass layups will degrade with UV exposure. The hotter the days and the more sun the roof is subjected to, the shorter the life span will be of the FRP layup. Unless the wax is a marine grade product with a high amount of UV protectors, waxing the roof will have little affect to prevent damage. The life span of the wax is short, and reapplication could be frequent depending on your environment. It is easy to test for damaged resin. Wet your finger and rub it across the fiberglass surface. If this results in a whitish powder, the resin has been damaged. Depending upon the exposure, this can occur in 5-10 years. The easiest and longest lasting repair is to then sand the roof and coat it with a white paint. There are many types of materials used in the construction of a FRP roof. Different manufacturers will use different ones, depending on their budgets and commitment to quality. It is difficult to directly compare the life span of various trailers, unless they were owned in the same location and conditions. It takes a couple of minutes to inspect the roof. Painting a roof is a half day DIY project. Fiberglass and aluminum are excellent roofing materials. After restoring three different steel roofs, I have firm plans to not own another steel horse trailer. |
    Location: Kinston, NC | Check out the SafeBump roof system, cool and durable
http://www.doubledtrailers.com/Video/technologies/safebump_and_safekick.htm Bartley Heath bartley@DoubleDTrailers.com Buy Factory Direct and $ave at DoubleDTrailers.com |
       Location: Northern Utah | The life expectancy of a fiberglass roof will depend on the quality and the materials used to make it. But go down to any marina and look at the 10-15 year old boats that sit out in the environment 365 days a year and see how the fiberglass holds up. |
