Butt Bar or Strap
blackcows
Posted 2011-03-05 5:37 AM (#131196)
Subject: Butt Bar or Strap
100100100100252525
My trailer has a butt bar behind the last horse to protect the door, a friends trailer has a strap which is a lot easier to use rather than fumbling around with a rigid bar and pin.  The bar certainly seems more solid but the strap is more convinent...anyone ever have trouble with a strap?
flatlandfilly
Reg. Jun 2006
Posted 2011-03-05 12:57 PM (#131206 - in reply to #131196)
Subject: RE: Butt Bar or Strap
My personal preference is for the bar because it is more solid and doesn't have the give of a strap The horse might test it once then quit. The strap has more give and the horse might keep pushing.
The purpose of the butt bar/strap is to keep the horse in in case the door flies open. Also to keep the horse from leaning on the door hard enough to pop it open.
If your horse is calm in the trailer and acustommed to it either would be okay.
Posted 2011-03-05 1:24 PM (#131207 - in reply to #131196)
The weakest part of either a bar, chain or strap is usually the attaching hardware. Most quality straps have a higher tensile strength than a chain. You can easily change from one type to another, if your trailer doesn't have dedicated attaching hardware.
Posted 2011-03-05 5:57 PM (#131221 - in reply to #131196)
If you are hauling big horses...use a butt bar...your rear trailer door will thank you in the morning...
