AC leak
DLR
Reg. Jul 2004
Posted 2011-03-02 6:46 AM (#130981)
Subject: AC leak
4-Star with roof mount air conditioner.  LQ was done by Bearcat in Indiana.  Leaking around the ac unit when it is raining.  I was told there is some type of molding the AC unit sits on. Does anyone know how to fix?
RAF
Reg. Jan 2009
Posted 2011-03-02 7:51 AM (#130983 - in reply to #130981)
Subject: RE: AC leak
take the bottom cover off the AC and tighten the 4 corner bolts . the unit has a rubber seal that has come loose .Good Luck
DD_TrailerMan
Reg. Jul 2008
Posted 2011-03-02 11:43 AM (#131007 - in reply to #130983)
It may be loose but don't over tighten.  My guess is that its overtightened and you will need a new seal.
Bartley Heath
bartley@DoubleDTrailers.com
Buy Factory Direct and $ave at DoubleDTrailers.com
DLR
Reg. Jul 2004
Posted 2011-03-02 7:52 PM (#131041 - in reply to #130981)
Thanks for the info.  I have owned for ten years and the bolts have not been tighten in that period so that may be the problem.
GRNMCHNEDAZE
Posted 2011-03-02 7:58 PM (#131042 - in reply to #130981)
10010010025
I purchased a gasket kit from adventurerv.net for about $15 if that's what it needs.
Posted 2011-03-02 10:36 PM (#131050 - in reply to #130981)
One of the members in our club had a similar problem. His was an older trailer with a leaking problem. He too had never tightened the mounting bolts. We loostened the four bolts, partially lifted the A/C unit, and discovered dirt and small debris betwee the seal and roof. The area was cleaned, the bolts retorqued, and the problem was eliminated.
DLR
Reg. Jul 2004
Posted 2011-03-04 7:19 AM (#131125 - in reply to #130981)
Thanks to all.  Now if the weather ever warms-up in Minnesota, we'll take a look at it.
