       Location: western PA | When you start seeing a lot of streaking, it is usually an indication that the caulking has been damaged by the UV exposure and weather. Clint uses quality products in his construction of the Blue Ribbon trailers. You should not have a problem for many years, because his newer trailers utilise the tape type of sealants. If your trailer is but a few years old, I would not mess with your present sealants. After five years or so from new, inspect the roof and determine the integrity of the sealants. If they are dried, brittle and missing, they will need attention. Chances are, you'll not have to do anything then, nor for another five years. |
