Location: NC | I have a 2005 trailer that the decals are splitting and coming loose in places from the elements. I'd like to remove them. Are there any products to remove them? If so, are there any issues, example.....will there be a color difference between where the decal was and the exposed skin? The decals are on white enamel and aluminum. Thanks for the advise! |
     Location: cedar rapids iowa | low dryer to soften and scrape with fingers or a plastic razor blade. The use an adhesive remover to get the glue off. It will look different under the stripes but a good polish will get it looking close. |
 Location: The Natural State | I also need to remove an old decal on the front of my trailer. Found a product called Vinyl Off that is supposed to remove the decal AND the adhesive underneath at the same time. It is a spray on product and is supposedly what many of the sign companies use for large, vehicle decal removal. I found it on ebay, it's about $16, but claims to save hours of time. Thinking about giving it a try. |
