Leaks
Flicka123
Reg. Dec 2010
Posted 2011-01-16 12:23 AM (#128947)
Subject: Leaks
Well, finally got a decent rain since buying my 2006 Sundowner Sunlite a little over a month ago. Discovered that the seams are cracked on the roof. What is the best way to repair? Is the Eternabond aluminum tape worth the cost? Or should I use a good caulking material?Thanks!
terri s
Posted 2011-01-16 8:04 AM (#128949 - in reply to #128947)
Subject: RE: Leaks
500100100100
I had mine taped many years ago; have never had a leak. I'd say yes.
HorseyHeidi
Reg. Jan 2008
Posted 2011-01-16 9:24 AM (#128951 - in reply to #128947)
Subject: RE: Leaks
Mine did the same thing when it arrived. All the roof caulking was cracked.  I read info on this forum scraped off all the old caulking and re-caulked the whole thing. It's now dry as can be. Good Luck!
Flicka123
Reg. Dec 2010
Posted 2011-01-16 9:37 AM (#128952 - in reply to #128947)
Subject: RE: Leaks
Thanks! I put a huge tarp over the trailer last evening, and it has rained A LOT overnight. I have been working on the LQ since I bought it, and it was frustrating to see the water running down the cedar walls! I spent yesterday sewing curtains and fortunately I was out there to find the water coming in and was able to get the trailer covered to prevent more damage! If I opt for the Eternabond, do you scrape the old caulk off before applying?
Posted 2011-01-16 10:48 AM (#128954 - in reply to #128947)
Subject: RE: Leaks
Whether you use tape, caulking or elastomeric remedies, the surface should be a clean as possible and free of any loose or cracked caulking materials.
