Best portable shower?
belhaven
Reg. Jul 2010
Posted 2011-01-04 4:36 PM (#128538)
Subject: Best portable shower?
I have researched and found these 3 have to most consistent positive reviews...thoughts on these (pros and cons) or alternative suggestions?The Coleman system with attachments for shower head and attachment to 5 gallon propane tankhttp://www.coleman.com/coleman/ColemanCom/subcategory.asp?CategoryID=2200The Eccotemphttp://www.amazon.com/Eccotemp-L5-Portable-Camp-Shower/dp/B00388PMEUor the Camp Chef Tritonhttp://www.amazon.com/Camp-Chef-Triton-Water-Heater/dp/B001J4AU2E
belhaven
Reg. Jul 2010
Posted 2011-01-04 7:46 PM (#128542 - in reply to #128538)
Subject: RE: Best portable shower?
Ew. my post came out so ugly and unreadable.Basically I am asking to compare the Coleman, Eccotemp and Triton.I was also thinking about carbon monoxide issues if using in the back of the trailer?
Edited by belhaven 2011-01-04 7:47 PM
twocloud
Reg. Aug 2009
Posted 2011-01-05 6:33 AM (#128563 - in reply to #128538)
My wife and I used a eccotemp in the back of the 3 horse with the top vents open and a side window open a couple inches, with no problems.  Eccotemps are great.
GRNMCHNEDAZE
Posted 2011-01-05 8:51 AM (#128564 - in reply to #128538)
10010010025
Wife I use the EZ tankless portable water heater/shower and its just awesome. We love it. Only about $100 too. I purchased it on ebay.
belhaven
Reg. Jul 2010
Posted 2011-01-05 12:26 PM (#128572 - in reply to #128563)
Originally written by twocloud on 2011-01-05 7:33 AM
Did you install a hook on the wall and just hang it up?
belhaven
Reg. Jul 2010
Posted 2011-01-05 12:27 PM (#128573 - in reply to #128564)
Originally written by GRNMCHNEDAZE on 2011-01-05 9:51 AM
Thank you I will look at that one as well.
GRNMCHNEDAZE
Posted 2011-01-05 1:05 PM (#128575 - in reply to #128538)
10010010025
We use carabiner's to attach the heater to the horse tie loops. It has a metal piece at the top that looks like a heavy duty picture frame hanger that a carabiner fits through perfectly.
We used this heater in <30 deg F weather (in the horse area) and you have to be careful to not burn yourself with the water temp. Original water temp was ~40 deg F.
It was cheap, a bit tedious to set up, but once its up, its awesome and works great. No problems.
Posted 2011-01-05 9:57 PM (#128610 - in reply to #128538)
1000500100100100252525
tank less systems work will we have one in the barn and no problems with it
belhaven
Reg. Jul 2010
Posted 2011-01-06 5:40 AM (#128614 - in reply to #128538)
Great suggestions!I found a good deal on Eccotemp so will give that one a go. I also bought a solar shower to try in case I needed a different heat source.Thanks again!
tucson
Reg. Dec 2009
Posted 2011-02-02 1:32 PM (#129684 - in reply to #128538)
I have both the eccotemp and a coleman they both work very good in different situations. The eccotemp needs pressured water, such as hydrant water or something else and the coleman you can get a pump for it.
