 Location: TX | I recently purchased a steel framed, aluminum skin gooseneck trailer and wish to insulate the DR. I know you can use the styrofoam board, but what about using regular blanket insulation. Would condensation be an issue? The R factor in the blanket insulation is higher. If it can be used, what is better, with the paper or without?Thanks! |
