      Location: Rocky Mount N.C. | "The green 40 amp fuse"... In the under hood fuse box, a 40 amp fuse goes in the first socket on the top left. Rip off the paper and pull out the red blank. Top left is looking at the fuse box from the drivers side front wheel. I think its labeled aux. post 1. This 40 amp fuse should power the 12 volt circuit that powers the 12 volt aux. feeding your trailer interior lights, load lights, etc. This plug wire will be hot all the time no matter if the truck is running or not, key is in the ignition or not. If the truck has a battery in it and the 40 amp fuse installed then the plug should be hot. There should have been a new 40 amp fuse shipped with your truck when it was new. It would have been in the glove box along with the trailer wiring pigtail... This is a GM 2500HD that you have with the factory trailering package and not a regular 2500..... Correct? If it's a regular 2500 or the 1500HD, then disregard anything I have posted on the matter because I don't have a clue about either of these two models.
Edited by retento 2010-11-28 2:47 PM
