Rips in wall liner
Lazy M
Reg. Feb 2005
Posted 2010-11-03 9:57 AM (#126612)
Subject: Rips in wall liner
HiMy horses are working their hind feet in my slant load trailer during travel. This has caused the thin rubber liner, 1/4", to become torn through to the bare aluminum wall from the floor up about 6". My local feed store has floor mats which are much thicker and I considered adding some of that to the bottom wall of the trailer but these only come in 6' lengths and my 2 horse trailer wall measures about 7'. They can't order any longer ones. Suggestions? Do I need to order liner from a manufacturer? I don't want to have this same problem, what thickness do I need to get?Thanks Joan
GRNMCHNEDAZE
Posted 2010-11-03 10:36 AM (#126613 - in reply to #126612)
Subject: RE: Rips in wall liner
10010010025
Could you split the difference and have 6" lacking on the front and rear of the wall? I wouldn't think the horses are getting their hooves that close to the wall corner and causing damage..
Just enough to cover what damage is done and prevent it further...
Posted 2010-11-03 11:21 AM (#126618 - in reply to #126612)
Originally written by Lazy M on 2010-11-03 10:57 AM
5x7 mat... http://www.farmtek.com/farm/supplies/prod1;;pgha1050_ha1055.html variable length option... http://www.farmtek.com/farm/supplies/ProductDisplay?catalogId=10052...
terri s
Posted 2010-11-03 11:46 AM (#126619 - in reply to #126612)
500100100100
I did what Paul said and it worked pretty well. I used silicone caulking to glue it to the walls at the time. I think 3M probably makes a better product but the caulking held up fine.
