   Location: Fort Madison, Iowa | I've read lots of good comments about Streakmaster and wondered if it's a good enough product to use to clean the aluminum floor in the horse compartment before applying a liner. Liners?? Wow! After reading past posts, what choices you have; Duraliner, Vortex, Dupli-color, Line-X, Rhino, Herculiner. Any comments on what you've found worked best or didn't? I need to get some aluminum welding work done from having a blow out on a tire and had orginally planned on working on putting in a liner this fall but until that work is done, I don't want to put in a liner yet. What temperatures would be best to apply a liner? Looks like it'll probably be a Spring project. Thanks! |
