     Location: sc | Grease. Oil runs off, grease is a more appropriate lube for that application. AFAIK the rear doors are to heavy NOT to have grease fittings if the hinges are expected to last.....unless you want to oil them every couple weeks. Drill and tap it for a zerk, drill a hole and use a rubber grease tip, use a grease needle....something to get grease in there. |
