Running Lights
blackcows
Posted 2010-09-20 5:25 AM (#125029)
Subject: Running Lights
100100100100252525
I have had my 01 Exiss for a few months now and am slowly fixing some things that were not working.  I had 3 running lights that were out and figured it was bulbs so I picked up some replacements but that didn't fix it, they are the one piece disposable lights.  Are the bases prone to wearing out?  Should I just replace them or try something different?
Edited by blackcows 2010-09-20 5:29 AM
Treashtrs
Reg. Jul 2010
Posted 2010-09-20 7:20 AM (#125030 - in reply to #125029)
Subject: RE: Running Lights
I would try replacing the whole thing on one of them and see what happens. I know that I had to replace the whole thing when I did the last trailer due to corrosion and they all worked great. Good luck and happy trails.www.treashorsetrailersales.com
wyndancer
Reg. Apr 2007
Posted 2010-09-20 8:24 AM (#125031 - in reply to #125029)
Most all the running lites on trailers are grounded through the base. And quite often the problem is corrosion in the mounting fasteners. Drill the pop rivets out, clean the base, use some dielectric grease, pop in some new rivets.
SRWilson
Reg. Jul 2010
Posted 2010-09-20 6:30 PM (#125067 - in reply to #125029)
Wyndancer said it.  I just got done replacing all he running lights on my old stock trailer.  The one piece guys either loose their ground through he rivet or the connection up to he socket for he bulb goes bad.  Its pretty easy to drill out and pop a new one in.
