      Location: Rocky Mount N.C. | Maybe the brakes just need adjusting.... If you just bought this trailer used, it may be a good idea to pull all the wheels, inspect and replace whatever needs replacing..... That's go's for the brakes, drums, springs, adjusters, bearings, wheel seals and check the build date on those tires while you got them off where you can really inspect them.... |
