| Does anyone know where I can find a simple speaker selector switch that I can use in my trailer to select between outside, inside, or both? I have seen these in trailers but can't seem to find one anywhere. I am thinking a simple dial that is the same size as a light switch. Mike |
 Location: Indiana | Have you checked your local Radio Shack? If you don't have any luck there, try a home theater installation company. |
  Location: Tennessee | I have used ones made by Niles several times, your best solution is (2) volume controls |
  Location: Washington DC | Here you go, Jazz sales sells one that I put in my LQ, seems to work just fine http://www.jazzsales.com/index.php?route=product/product&path=171_123&product_id=635 |
    Location: Minneapolis, MN | Most trailers that I've seen, short of the high end stuff, have two speakers in, two speakers out. So you could use, as I did, the fade for front/rear, and balance for in/out. |
      Location: Missouri | Our trailer is wired so the rear speakers are outside and the front speakers are inside. Then I use the F/R fade to adjust the audio outside. |
