| I got the old batteries out and messed up my cables ...so now I dont know which ones attached where.... I got the parallel circuit connection understood...but I still have my hydralic jack cable as well as others that I have NO CLUE what they are for.... and yes guys you will like this statement!...this is why this woman does not do these things...why oh why did I not label them! |
      Location: Decatur, Texas | Originally written by twiggles64 on 2010-09-07 9:02 PM I got the old batteries out and messed up my cables ...so now I dont know which ones attached where.... I got the parallel circuit connection understood...but I still have my hydralic jack cable as well as others that I have NO CLUE what they are for.... and yes guys you will like this statement!...this is why this woman does not do these things...why oh why did I not label them! Well without looking at yours it will be hard to tell every wire for sure. Maybe telling us what brand trailer you have will be a good start. With my trailer I have a few small gauge wires that run to the hot side of the battery and the hydro jack cable runs to the hot and neg side. Just follow the larger cables and one should hook to the trailer or jack frame and the other will run to a electric motor located on the jack. Mine has the jack running to one battery and main trailer power running to the other but also hook paralled(spell check?) then the 3 or 4 small wires are run to one of the batteries. Hope this helps. Don't forget to list you trailer brand and someone else could jump in too. |
| Thanks Hog...I have a 06 Cimarron 3h with and Outlaw conversion package.... |
      Location: Decatur, Texas | Originally written by twiggles64 on 2010-09-07 9:49 PM
Thanks Hog...I have a 06 Cimarron 3h with and Outlaw conversion package.... Ok, What I would do to make sure is call Outlaw Conversions and the guys there can tell you exactly what goes where. They might even be able to fax you a diagram to help show you. Outlaw is really good about keeping track of what they install and how it is hooked up on trailers and the customer service is outstanding! Outlaw Conversions Stephenville, TX 254-968-5733
Edited by hogtownboss 2010-09-07 10:22 PM
| Great minds think alike Hog...this was on my agenda to do today! Why I didnt think about it in the first place I dont know! Gonna call them at lunch! Thanks |
Thanks Hog...I have a 06 Cimarron 3h with and Outlaw conversion package.... OOOPPPPPSSSSS It's a JAG Conversion package! Man these senior moments are killing me! |
     Location: Where the wind comes sweepin' down the plain... | Going by memory since I am not looking at mine right this minute...Hydraulic jack should have a positive and a negative that go to one battery. If you have the other main wires hooked up, you should be able to trace and make sure nothing else grounds to the frame right there, but they all should be leads off of the positive of the other battery. That is how mine is. |
      Location: Decatur, Texas | Originally written by twiggles64 on 2010-09-08 9:59 AM Originally written by twiggles64 on 2010-09-07 9:49 PM
Thanks Hog...I have a 06 Cimarron 3h with and Outlaw conversion package.... OOOPPPPPSSSSS It's a JAG Conversion package! Man these senior moments are killing me! I'm not sure if they are still around or not I did find their number still listed on HTW. 888-229-7763 also I found 2 Cimmarron dealers listed for OK that showed to use Jag Conversions. If the conversion company is no longer you might call the dealer. |
| Originally written by hogtownboss on 2010-09-08 10:36 AM Originally written by twiggles64 on 2010-09-08 9:59 AM Originally written by twiggles64 on 2010-09-07 9:49 PM
Thanks Hog...I have a 06 Cimarron 3h with and Outlaw conversion package.... OOOPPPPPSSSSS It's a JAG Conversion package! Man these senior moments are killing me! I'm not sure if they are still around or not I did find their number still listed on HTW. 888-229-7763 also I found 2 Cimmarron dealers listed for OK that showed to use Jag Conversions. If the conversion company is no longer you might call the dealer. Wow..hope they are still around....thought they were a fairly big cinversion company but I guess economy getting everyone! |
| Well hogtown you were correct JAG conversions evidently is not longer in business or their phone number has changed and they have closed website.......Now what to do??????? |
      Location: Rocky Mount N.C. | Originally written by twiggles64 on 2010-09-08 2:22 PM Well hogtown you were correct JAG conversions evidently is not longer in business or their phone number has changed and they have closed website.......Now what to do??????? Click on this link, it may help... http://www.dkimages.com/discover/DKIMAGES/Discover/previews/881/35021827.JPG If you know your ABC's and have some masking tape, it only takes a few extra minutes to mark it all..... Before you forget where it go's.
Edited by retento 2010-09-08 1:37 PM
      Location: Rocky Mount N.C. | You need an OHM meter, test light, a jumper wire or three, some correct fuses and something to scream at.... You'll get it figured out. |
| Originally written by retento on 2010-09-08 1:39 PM You need an OHM meter, test light, a jumper wire or three, some correct fuses and something to scream at.... You'll get it figured out. LOL retento...that made my day!...I do remember where a few of them go.... This is what I remember! Some are marked...red and yellow.... Battery one: positive-red from master switch,parallel cable to 2nd battery-positive- negative-parallel cable to 2nd battery-negative. My hydra jack was hooked to battery 1- I know one was hooked to negative and not sure where other one was hooked....has 2 wires and fuse Battery 2: Positive-parallel cable from battery one-positive...all yellow cables (3 total one with 15 amp fuse) Negative-parallel cable from battery one still have a white wire,a second cable from master switch |
     Location: Where the wind comes sweepin' down the plain... | Originally written by twiggles64 on 2010-09-08 1:55 PM Originally written by retento on 2010-09-08 1:39 PM You need an OHM meter, test light, a jumper wire or three, some correct fuses and something to scream at.... You'll get it figured out. LOL retento...that made my day!...I do remember where a few of them go.... This is what I remember! Some are marked...red and yellow.... Battery one: positive-red from master switch,parallel cable to 2nd battery-positive- negative-parallel cable to 2nd battery-negative. My hydra jack was hooked to battery 1- I know one was hooked to negative and not sure where other one was hooked....has 2 wires and fuse The fused wire will go to the positive on that battery. Battery 2: Positive-parallel cable from battery one-positive...all yellow cables (3 total one with 15 amp fuse) Negative-parallel cable from battery one still have a white wire,a second cable from master switch It should be a positive wire as well. I responded above in your quote. |
        Location: Vermont | Next time...take BEFORE PICTURES of the cable connections... |
| Yes Paul I know ....... BUT with a few phone calls this afternoon...I have power restored! SUCCESSFULLY!!!!!!!!! and to let everyone know JAG conversions is now HG Conversions.......THANKS to hogboss and everyone else that helped....A HUGE THANKS to David at Shawnee Trailers who took the time to walk me thru it! Class ACT! The cables will be labeled tomorrow...already have the tags just didnt have a permanant marker this evening and I will take pictures also! LESSON LEARNED!
Edited by twiggles64 2010-09-08 9:11 PM
