| Okay, so I took my Merhow with the bad walls in to the trailer shop and they determined the only way to fix it is to replace the side walls on the trailer. The problem is, they can't find anyone that sells a big enough piece to do the job. He suggested I start looking around. I contacted Crane Composites (which seems to manufacture the right stuff) but I can't find a distributor that carries the stuff. Anyone have any ideas? Thanks! |
      Location: Home of Wild Turkey Whiskey | Where are you located?, there are several houseboat manufacturers in southern Kentucky that can do them. |
| Does Merhow (the company) have information where they bought the stuff? The other idea about contacting RV companies might be useful.. see which ones have the FRP walls on their products.. esp if they are still making them!!! Jbsny |
| Thanks! I am in Lexington, KY so South. KY wouldn't be very far if they have the materials. My repair shop called Merhow; they gave him the name of a company neither one of us can find. |
 Location: Colorado | You might try truck body manufacturers. Morgan and Supreme are two national companies that build FRP bodies that come to mind. |
| Looks like HWBar has the best suggestions. Maybe give him a PM? Jbsny |
      Location: Home of Wild Turkey Whiskey | I have talked with these folks about conversions in the past, they are super folks. Give them a try. They can make a FRP wall 100" if needed. http://www.lakeviewyachts.com/contact-us
Edited by HWBar 2010-08-27 5:25 AM
| Thank you for the suggestions! Hopefully I can get an idea of if it can be fixed, and if the cost is reasonable to do so.
Edited by OnTheRoadAgain 2010-08-27 6:53 AM
