| HI every one I am new here. I am needing to remove the 2 slant dividers from my 2001 Exis horse trailer to pick up my POA weanling next week. Im just not sure in how they come out, or go back in since the next day I will need them in to haul my other horse to a show. If anyone can assist me in that it would be greatly appriciated. Thanks Gina |
    Location: michigan | It is possible to just tie them open rather than removing them? I did this when i brought a weanling home.... |
| Yea I think I am going to have to figure out a good way to tie them to the rear tack, b/c they are spring loaded and do not look like they will come out easily or go in right if I do get them to come out. Thanks |
  Location: White Lake, MI | If they're like mine were, first you need to release the spring. There should be a loop on the end of the spring that you can grab onto and unhook it from the channel on the bottom of the divider. Once the tension is off, have one person hold the divider while another takes out the two pins from the hinges on the head side. You might have to wiggle the divider up and down a little to get the pins out. Once the pins are out, the divider should be free to pull out. I was able to remove them by myself, but it's much easier with two people. If the first divider has a stud wall, remove the stud wall first. It should be held on with two pins on the bottom of the divider and two pins on the wall. I found it easiest to remove the pins on the bottom of the divider first, then wiggle the divider up and down to get the pins out of the wall. |
    Location: michigan | OK- my dividers are not spring loaded so that would make a difference. |
| Zip, I just removed mine this weekend. Mine (Elite) just sit on two pins. To get the back one out, all we had to do was pull up. The stud wall had an extra pin for the lower portion. That pin had to be pulled out before we pulled the entire wall out. With two people it was a snap. |
