Cleaning water caddies
traveller
Reg. Jun 2005
Posted 2010-08-17 4:59 PM (#123673)
Subject: Cleaning water caddies
What's the best way to clean out the portable water caddy for the horse trailer?  I have hard water from a well and have lots of deposits inside the tank.  Thanks in advance
Posted 2010-08-17 6:38 PM (#123676 - in reply to #123673)
Subject: RE: Cleaning water caddies
Pour in a gallon of white vinegar and swish it around to coat all the insides of the tank. Reagitate every hour or so. It may take a day to remove all the deposits. Flush with water when you're finished.
brushycreekranch
Reg. Jun 2006
Posted 2010-08-18 7:02 AM (#123697 - in reply to #123673)
500100100100100
If you have the deposits in your tank, then most likely, they are in the water heater, too. You can buy a water heater flushing tool at Camping World for $5. Hubby flushes the water heater , and adds a little clorine to the water tank for the next trip. Then, every so often, I just pop a RV fresh water tablet into the water fill inlet before I refill the tank. Those mineral deposits can cause a foul odor inside the LQ.
traveller
Reg. Jun 2005
Posted 2010-08-18 5:12 PM (#123734 - in reply to #123673)
Thank you both, I appreciate the tip on the water heater but I don't use the water from home in the trailer due to the issue with the hard water.  We don't use this water to drink or cook with.  It is a good tip anyway because there could be issues where I fill my water tank.
