leaks in tack room
corvettebuyer
Reg. Aug 2010
Posted 2010-08-14 8:12 PM (#123526)
Subject: leaks in tack room
Hey I just bought a silver star 3 horse alum. trailer and just discovered about 6 leaks it looks like it is coming from where the roof meets the wall thanks for any help
301duster
Reg. Jan 2009
Posted 2010-08-14 8:48 PM (#123527 - in reply to #123526)
Subject: RE: leaks in tack room
Ruscoe brand, permanent sealer. Sorry not smart enough to link it. Comes up on google search. I've used it underneath water, below freezing to seal stock tanks, this stuff works very good!!!
corvettebuyer
Reg. Aug 2010
Posted 2010-08-15 7:31 AM (#123536 - in reply to #123526)
thanks for the info it looks like good stuff should I remove the old before installing the new sealent thanks
301duster
Reg. Jan 2009
Posted 2010-08-15 8:51 AM (#123538 - in reply to #123526)
Yeah, clean it as good as you can. Once you put down the ruscoe and it cures it's very difficult to remove. You can do it but it doesn't just peel off like some of the other. It's best to do it right the first time. It won't seal as well if it's stuck to something that's loose.
