Location: SC | Thank you for this informative forum! After searching archives I still don't understand tongue weight. Is it the same as pin weight? My truck is 1996 Dodge Ram 2500 Club Cab HD 4WD. 5.9 L diesel, 3.54 axle ratio, HD manual transmission w/OD. HD service group. GVW 8800, front axle 4850, rear axle 6084, tongue weight listed as 900#. Max trailer weight 11,900. I have checked the manual, the inside of door and a Dodge service guy looked up my VIN on internet to verify.I'd like to find a used smaller GN LQ that this truck can safely handle. I usually only haul one 900# horse but may have 2. If 20-25% of total trailer weight is used to calculate pin weight, 900# doesn't sound right. Could someone clarify this for me?Paulette |
       Location: Northern Utah | We usually refer to tongue weight for the weight on the hitch for bumper pull trailers. Whereas Pin weight is the weight on the Gooseneck hitch for GN trailers. I think there are numerous people who would use the term interchangeable, Meaning the downward weight on any hitch. |
       Location: western PA | Ditto what PH related. The tongue of a BP trailer is somewhat self explainatory. I think the pin weight for a GN is related to the tubular, vertical type of hitch. The actual weights of the two types of hitches are not directly comparable, with their resulting effects on the truck. The pulling capabilities of a vehicle will change depending on the type of hitch, so things get a little confusing. If a truck has a rating of a BP tongue weight of 500 #s, he could conceivably carry two or even three times that amount with a bed mounted hitch and a GN trailer. The towing weight is what can be pulled, and tongue weights will vary with the various trailers, the installed equippment and how many horses are being hauled. There are many variables in a towing rig, the truck's capabilities, the trailer's total weight, the proportion of that weight on the hitch, and the varying amounts of weight that will be loaded into the trailer. There are even further considerations when loading. Many trailers have different axle locations and depending on where, within the trailers the horses are placed, the loads will change the various weights on the hitches differently from one another. When you include the individual types of usage each owner expects, even more differences are added to the question. That's why when someone asks, "what can I pull or carry?", he will receive answers that will considerably vary. Almost everyone's rig differs from another's, even if the brands of equippment were identical, the loading will differ. It can be a confusing situation to try to establish an exact response to the question. Ultimately it boils down to trial and error, and the best guess possible to start. |
Location: SC | Thank you. Really appreciate the explanation. |
Location: Fort Lauderdale, FL | I have weighed my truck and trailer combos at the truck stop on several occasions. How does one go about easily determining the ACTUAL tongue weight on a BP? The only way I can think to do it is to unhook the trailer with just the tongue over the scale. I don't think the truckers would like that very much at the local truck stop!Any other suggestions? I don't like having horses anywhere near an unhooked trailer, so getting the true tongue weight partially and fully loaded is a complete mystery to me...Better ideas? Mine doesn't sound so great... |
      Location: Rocky Mount N.C. | Weigh the truck with the loaded trailer attached but trailer not on the scale, then next time by the scale weigh just the truck.... Compare the two. |
Location: Fort Lauderdale, FL | That's much easier! I already know my truck weighs 5,760 pounds, so I will just head over to the truck scale the next time the trailer is hooked. My F550 weighs 9,150 pounds and my empty 1995 Sundowner 4H LQ weighs 12,100! I'm not gonna pull it with my Ram 2500, that's for sure! |
       Location: Northern Utah | A lot of the scales can weigh each axle. Get the weight for your rear axle with out the trailer hooked and up and drive across the scale with the trailer hooked up. The difference in the rear axle weight will be the tongue weight. All the truck stops on the Utah Point of Entry weigh by individual axle. as you drive across you get a Front axle, rear axle, and trailer axle weights. Add the all together to get the total weight for the rig. |
