electrical installation
Lazy M
Reg. Feb 2005
Posted 2010-07-24 10:14 PM (#122763)
Subject: electrical installation
Hi,I just have a simple weekender in my trailer, currently my dressing room lights run off the 12 volt battery mounted on the trailer which I recharge with a battery charger when needed. I would like to have 110 added to run a dorm refrigerator, microwave, etc. The 12 volt would remain separate. A conversion company in my area has quoted me several hundred dollars to install a light fixture, 2 outlets and what he calls a power center. The power center is the greatest cost of this estimate. I am being told that the power center is necessary because of a possible shock hazard associated with using a breaker box. Is there a safe and less expensive alternative to putting in a power center?Thanks Joan
Posted 2010-07-25 5:50 PM (#122779 - in reply to #122763)
Subject: RE: electrical installation
The answer depwnds on what is in the "power center". I think a safe installation in a trailer consists of a breaker or fuse at the inlet to protect the wiring.... AND a GFI installed at the outlets or a GFI breaker will protect you from shock.
