| We got our first LQ trailer and use it most every weekend to go to shows. During the week it sits outside, closed up and it really seems to get musty, hot, humid, stuffy inside....just like anyplace gets that is closed up in 90 degree summer weather. After each weekend we do a good job of cleaning out dirty cloths, dumping trash, and get things put away but when we open things up on Friday night to start packing for the weekend shows we climb into a stuffy, humid, still LQ. It would be nice to be able to leave a window open to get a little fresh air moving though during the week but any rain would wet the inside. Any tips or tricks to keep the LQ a little more fresh? |
       Location: western PA | Can you leave one of you vents partially open? If you have a walk through door, leave it open along with some stall windows. If you leave power on, a dehumidifier will keep the humidity down, but increase the inside heat temps. Your only real recourse is to provide an airflow. They make vent covers that are affixed to the roof, covering a vent. The vent can then be left open without the fear of water damage inside. They look something similar to an air conditioner shroud. http://www.pplmotorhomes.com/parts/rv-vents/rv-vent-covers.htm |
    Location: Florida | We keep ours shut tight and the fridge doors wide open when not in use. I keep all the shades drawn to keep the light out. Cabinet doors open under the sink and fridge while she sits. Yupper she gets hot. I have a few of those closet air fresheners hidden about. but otherwise when it comes time I go in and turn on the fridge and she doesn't get opened up until we arrive. I really do not have any musty smells. You may have water getting in someplace. You can check your water connections for leaks I found my hw tank and shower and loosened up this year and needed gentle snugs. Also check you windows and make sure the weep holes are working properly (Use a hose) if not, high pressure from the outside will blast the crud out of the holes and open them up. (Another lesson we just learned, pollen clog I suspected). We always open the faucetts after the water presure has been removed just to take the stress of the lines. I keep a gallon of diluted Mr Clean when we arrive home I add a few cupfuls to the drains to fill the traps and to the toilet bowl. This helps to keep the flies from coming thru into the LQ while it sits. And smells fresh too :) |
      Location: Rocky Mount N.C. | When the water evaporates out of the sink drain it will allow the "VAPORS" from the holding tanks to enter the LQ. That Mr. Clean or either Pine Sol works good. We now keep ours in the barn with some of the trailer windows open. Last Wednesday it was 103 outside in the sun, it was 83 inside the trailer with several windows open while parked in the barn with all the barn doors open. |
    Location: michigan | I also keep a window or two open for air. I also place some air freshers in the LQ and mid tack..if nothing more than to make it a bit more pleasant and for my clothes. |
   Location: Harrisburg, PA | I recall seeing those solar powered fans that you can put in your car window. I would look for one of those that could be installed in the trailer somewhere.
Plus all of the other things mentioned so far. Humidity is a challenging problem to solve. |
    Location: MS | Originally written by farmbabe on 2010-07-11 2:37 PM I also keep a window or two open for air. I also place some air freshers in the LQ and mid tack..if nothing more than to make it a bit more pleasant and for my clothes. How do you leave windows open without it raining in?? I run the fan on the AC, but not the AC itself. Even just the fan increased the power bill double. Mainly I do that to keep wasps from building in the unit on top of the trailer. They actually bent the blades when they built there and I turned on the AC!
Edited by Linda Y 2010-07-11 4:54 PM
    Location: Vanzant, Missouri | I keep my windows opened. Even in the rain. I have louvered type window instead of the slider type. I also have a screen door so when I'm home I usually leave the door open. Then close it at night.. |
    Location: michigan | the trailer is usually near the barn ( thus blocking most of the weather) and the windows I leave partially open are smaller such as the window on the midtack door. I crack the table window open a bit, if it rains it just gets the small dinnette table a bit wet but nothing big. |
        Location: North Carolina | We use "Damp-rid" it's a chemical dehumidifier. Nothing more than flakes of calcium chloride. I pour the used solution on the gravel road for dust control. Also helps keep the mold from the tack. |
    Location: Indiana | Most of our windows are louvered -- so we can keep them open a bit - the slider windows are only in the doors |
| The Damp Rid will really help,also,there is a product called Fresh Air (I think) that you can leave open and it leaves a nice scent.I'll have to double check on the name and who makes it. We installed a MAXX Air vent fan in the bathroom where the crankup was and it was the best investment we've ever made.We leave it open and when we are going to get in the trailer to prepare for a trip,we turn on the reverse and it will exhaust the stale hot air in a matter of a minute or two.It's pricey but it is what they install on the pusher RV's and it is the best. http://www.maxxair.com/
Edited by crowleysridgegirl 2010-07-11 9:13 PM
   Location: Illinois | ***WARNING*** NEVER NEVER NEVER put Pine SOL down your drains...it will eat the plastic holding tank....a friend found this out the hard way....a very expensive lesson to learn. |
 Location: Indiana | Maxair vents are the best and easiest way to solve your problem. You can get them with or without a fan. You can keep the vent open year round if you like. The fan can be set up to suck air our or blow air down. Any good RV dealer and/or service center will have them. If your LQ was converted right, their should be power run near the vent already, so that will make it easier for a do it your self job to. |
| Right! We really do enjoy having ours.also powerful and quick to remove humidity caused by the shower,also. |
      Location: Rocky Mount N.C. | Originally written by To Much Trouble on 2010-07-13 10:47 AM
***WARNING*** NEVER NEVER NEVER put Pine SOL down your drains...it will eat the plastic holding tank....a friend found this out the hard way....a very expensive lesson to learn. Then why doesn't it eat the plastic bottle that it comes in? Why hasn't our Coleman "port-a-pottie" black water holding tank as well as the clean tank self desrtucted after 10 years of use? I think you got Pine Sol confused with "Red Devil" lye..... Maybe your friend needs to change their diet....!!! Wouldn't think that soap would ruin a waste tank. |
 Location: Indiana | I've heard it before too. Thats why AquaChem is recommended or its generic partner. Holding tanks are usually ABS. They are more susepctable to chemicals. The plastic bottle Pinesol comes in is a totaly different kind of plastic. I'm sure Gard could give you a more detailed explaination on this. |
   Location: Illinois | I cannot answer WHY...but I seen the damage for myself..and the RV place that did the repairs has pictures posted on their bulletin board as a warning NOT to pour PineSol down into your holding tank...it cost my friend several hundred dollars to have tanks replaced..repair was not an option. I thought I might pass this imfo on to say someone the expense and grief of destroying their tanks |
    Location: michigan | From this source-http://newcarbuyingguide.com/index.php/news/main/4838/event=viewUse only high quality, biogradable enzyme and bacterial tank treatments in holding tanks. Never use chemicals containing formaldehyde or homemade ones that contain pine oil or Pine Sol. Formaldehydes are dangerous to sewage treatment plants and septic systems, while pine oil can cause long term damage to the seals on the tank gate valves causing leakage. |
    Location: michigan | This from another site-http://www.squidoo.com/rvdumping This tidbit discusses how to keep the sludge out of your black tank. This advice comes from a company who came to a talk at a local RV club meeting. I read this on one of the RV forums and thought it had some validity so will pass this along.The folks at this company say that they use Pine Sol in their RV tanks when they travel... a few ounces each time after they dump... Pine Sol is cheap (sometimes 99 cents in the dollar store) and a bottle will last a long time... they said it does the trick and you can save a lot of money... for short camping trips where you dump more frequently (less than full tank) you have spent a couple of cents, instead of a dollar or two of the other stuff...People asked about it dissolving "dark matter", and they did not recommend doing that as it forms sludge in the bottom that is sometimes hard to get out when you dump... better to have those little missiles floating on out in the hose they say... and they have cleaned dry sludge from many tanks as it is their business... some people store tanks without a thorough flush (or having that capability) and the sludge dries over time... Keeping a lot of water in the tank is important... As a little input from my own experience, I once time dumped on the way home but forgot to fill the tank with fresh water and chemicals, 2 weeks later it was bone dry and the black valve handle was very, very hard to move. We had to take the whole black tank assebly apart, clean the valve and gaskets and re-assemble it all. For good measure we did the grey tank assembly as well.Also, they said in all the tanks they have cleaned, toilet paper has not been the problem.. sludge or other buildup... as I have heard before, they suggested some soap in the tank filled with water and then drive over bumpy roads to clean the sensors and sides... Some sensors are on the outside of the tank, but buildup on the sides can still affect the reading... Pine Sol may help prevent that...Pine Sol is a cheaper solution to more frequent dumps with the short trips.... Someone asked if the Pine Sol would damage the seals... they said it does not unless you used a 50/50 solution over a very long time... they said in 12-15 years of heavy usage you may need to replace your blade valve...Pine Sol has a very strong smell, so some will be put off by that. I will do some more research and perhaps try it out myself next year.This article was reproduced with input from RV Stuff N Thingz. |
      Location: Rocky Mount N.C. | I've used Pine Sol for years and never had any trouble with it eating up any poly tank. I would imagine if you dumped the 100% Pine Sol in a empty tank and left it sitting for a long period it may have an adverse effect in the area that it may have pooled in.... I would have to imagine that someone may have dumped a bottle of pin cleaner, then someone else may have poured in another cleaner, maybe some bleach or the RV tank smell good stuff, then some sort of chemical reaction could have occured, causing the poly take to loose it's structural integrity... So if your afraid the Pine Sol will harm your holding tanks, don't use it..... As for me, I'll continue to use the Pine Sol in my holding tank and keep all my tires inflated to the maximum pressures as stated on said tire's sidewall!!! P.S. I'll let you all know when my tank takes a dump and all my tires blow out!! LOL!!
Edited by retento 2010-07-13 3:16 PM
    Location: Florida | I gotta say I dilutte the no name pine Sol from Wally market. But as always I appreciate learning new things and maybe I will look in the camping section for a better item. But... I like hearing every now and then a shreek from the house "Where has the dam Pine Sol gone to again!"  |
 Location: desert hills, az | Has anybody used Simple Green? |
      Location: Rocky Mount N.C. | Never used in a dark tank, but it will clean black streaks off the trailers exterior as well as the wax.... Does a good job on an awning also. Don't be afraid to rinse with copious quanities of agua. I would be a bit afraid of the "Simple Green" vapors in a confined space, such as the vapors leaching from a porly vented tank, back into a closed up trailer living area. A glance at the products MSDS sheet may prove me wrong. |
| After we dump our black/grey tanks,I always pour about 1/2 bottle of Lemon Joy dishwashing liquid in the toilet and dump in the ice cubes that are in the trays remaining,about 3 trays full.I think it helps keep it clean as it goes down the road,it's scouring and sloshing.Never have used Pine Sol,I just use the Campa Chem stuff while sitting still. RV dealer told me about the Lemon Joy deal. |
 Location: Indiana | I've nevethought of that. I always just dump an 8# bag of ice and a bucket of water to beat the S*** out of it. I assume you use bleach or for the fresh. |
   Location: Illinois | the local RV dealer suggested we use baking soda to freshen the tanks..dump a couple box in stool / sink and alittle water..he also suggested a couple boxes added to the fresh water tank to remove the nasty odor from the water...I do not drink or cook with the tank water..just shower/ clean up, wash dishes etc. And baking is rather cheap too..I also keep one in fridge |
