Trying to wire new trailer end 7 Blade plug...sparks!
brendaclemens
Reg. Jan 2009
Posted 2010-07-04 8:16 PM (#121891)
Subject: Trying to wire new trailer end 7 Blade plug...sparks!
OK, maybe this is normal, but the sparks startled me. I was trying to thread the wires thru the new plug and when I think Black & White touch, it sparks...should I just shove it thru?...or will I blow something up?! Sorry :( changing light bulbs makes me nervous...I'm just trying to get this done...am having a hard time finding help before a ride.
chadsalt
Posted 2010-07-04 9:26 PM (#121893 - in reply to #121891)
Subject: RE: Trying to wire new trailer end 7 Blade plug...sparks!
1000100100100100
Disconnect the battery, or wrap some tape on the wires.  Sparks are not 'normal' or good.
brendaclemens
Reg. Jan 2009
Posted 2010-07-04 9:39 PM (#121894 - in reply to #121893)
TAPE! Right...I guess I was so frazzled I didn't think of that...lol. Thank you!
tobruk
Posted 2010-07-04 10:09 PM (#121897 - in reply to #121891)
You might want to check the recharge line fuse which may have been blown when you had the "sparks." That's usually one of the fuses up under the hood in the distribution panel.
yeehaw
Posted 2010-07-08 7:20 PM (#122067 - in reply to #121897)
Originally written by tobruk on 2010-07-04 11:09 PM
Excellent advice the black and white wires are normally the +12(black) and ground(white)...sparks would probably take out the fuse
Edited by yeehaw 2010-07-08 7:22 PM
