Sticky Sliders
To Much Trouble
Reg. Dec 2009
Posted 2010-07-04 9:43 AM (#121866)
Subject: Sticky Sliders
 I thought I read a post about fixing the sticky slider windows...but I can't seem to find it... maybe it wasn't even on this board...any suggestions on what to do to get them to slide easier..I have a couple that I can barely budge..I figure the tracks need cleaned out also..whats the best stuff to use / lubricate ?  THANKS
Phoresic
Reg. May 2010
Posted 2010-07-04 10:58 AM (#121871 - in reply to #121866)
Subject: RE: Sticky Sliders
500
I read that too.  I was about a week ago I think.  The recommendation was a dry lube that is available at Walmart.  I *think* it was a graphite lubricant, but I'm not sure.
I'll look for the post too as I wanted to buy some and just hadn't gotten around to it.
Posted 2010-07-04 10:59 AM (#121872 - in reply to #121866)
This is what I use to keep my windows sliding smoothly... http://www.amazon.com/CRC-05074-Silicone-Multi-Use-Lubricant/dp/B000BXKZUG
Wash and clean the window and track, then spray the window track, it's the window that's trying to stick to the rubber seal. Your local hardware store or ---mart has a supply of silicone spray lubricants.
Don't use graphite on the windows unless you want more black streaks running down the side of your trailer....
Edited by retento 2010-07-04 11:01 AM
Phoresic
Reg. May 2010
Posted 2010-07-04 11:03 AM (#121873 - in reply to #121866)
500
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=13821&posts=10
Phoresic
Reg. May 2010
Posted 2010-07-04 11:04 AM (#121874 - in reply to #121866)
500
Yeah, retento, I was looking for your post.  I'm glad you were here to repost it.
To Much Trouble
Reg. Dec 2009
Posted 2010-07-07 12:30 PM (#121999 - in reply to #121866)
STICKY SLIDERS part 2:
      OK, anyone got any ideas on how to clean out the goove ( rubber)that the windows slide in...I purchased the spray to lubricate..but the tracts are horrible and caked with crud...any suggestions?  I tryed blowing them out with air hose..it did very little.. do I need some type of brush?
Posted 2010-07-07 12:37 PM (#122000 - in reply to #121866)
A brush no wider than a tooth brush should work, you reckon??
To Much Trouble
Reg. Dec 2009
Posted 2010-07-13 9:43 AM (#122289 - in reply to #121866)
WAHOOO...got the gooved cleaned out and sprayed with the CRC..they are working perfectly,smoothly and with no irritating squeak...THANKS ALL
