Location: Thunder Bay, On, Can | Hi all: we have a 3 horse exiss with LQ that I tow with a 1998 f250, triton engine (gas), single axel, short box, 4x4. I have a couple of questions. I have michelin tires on the truck and am wondering if I should have them at max tire pressure (80 psi is listed on side of tire). The gvwr of the trailer is approx 9500 lbs. We tow two horses so I'm assuming we are usually a bit under that weight? I'm also wondering if I should have the overdrive off all of the time or just in hilly/stop and go type situations. This truck is in great shape and I would like to keep it for a couple of more years. I know that a diesel would give better towing/mileage performance but just can't afford to switch right now. Any advice on towing with this setup would be greatly appreciated. thanks for your time Maryann | |
 Location: Colorado | I would have the tire pressure at the max with what you're towing. With an automatic, I'll take it out of overdrive if it's wanting to "hunt", or shift back and forth between direct and overdrive. Otherwise I'll leave it alone. | |
Location: Thunder Bay, On, Can | Thanks for the reply. I'm sure I'll have more questions and appreciate your taking time to answer. Maryann | |
   Location: Danielsville Georgia | Rear tires to 80 not the fronts. | |
Location: Thunder Bay, On, Can | Thanks, I figured that. Is it ok to keep them at 80 even when not hauling? | |
   Location: Danielsville Georgia | If you wear a kidney belt and don't mind eating the tread out of the center of your tires.On a SRW they are easy to adjust hauling and non hauling. Use to adjust mine weekly from 55 to 8o etc. I have a little air pump and a good gauge. Run fronts on what door tire specs say.More then likly around 55 on a gas engine.65 on a diesel.(heavier) | |
Location: Thunder Bay, On, Can | thank you. I'm assuming SRW is single rear wheel? | |
       Location: western PA | We keep our truck and trailers' tires aired at 80 psi front and rear, year round. No problems with uneven tire wear and don't have to constantly adjust the pressures. | |
     Location: Where the wind comes sweepin' down the plain... | I keep mine at 80 front and rear also. Never had an issue. Yes it does ride a bit rougher, but it is a dually and I don't expect it to ride like a car. | |
     Location: Where the wind comes sweepin' down the plain... | I have friends that run 65 fronts, 80 rears, and others that run 65 around. One peeled a tread off a rear tire two weeks ago and tore a chunk out of his fender on the truck. Another is changing tires constanttly. They have both asked me about tire problems. Never had any, but I do run my tires at max on the truck and trailers. Either I have just been lucky, or it works. Since I haven't yet won the lottery, I am going with it works because I have done it that way for 15 plus years. | |
      Location: Rocky Mount N.C. | I run the max. as stated on the tires sidewall. Same for the front, rear, truck and trailer which happens to be 80 psi..... No abnormal wear, no tread peeling, no blowouts, (no kidney belts, messin' with ya hounddog LOL!!)... Those lrE, Michelin, LTX M/S, 215-85-16's on my GM dually need the full 80 psi to carry the load and not be squishy/squirmy. They are rated at 2686 single and 24?? as duals. Don't take alot to load them up. If I ran 65 psi like it says on the door, the fronts would be gnawing the outer shoulders off quicker than I could keep them rotated. It does ride some better with 65 psi, but I'm not going to change air pressue every time I drop or get under the trailer, truck stays hitch to the trailer 99% or the time. Only time it's not is when we're at a show, or it's at the shop for PM service. I bought a new GMC 2500HD a couple weeks ago to use as my run around/two horse bumper pull truck. The first thing I did when I got home was bring the tire pressures up to 80 psi. Now it handles like a truck. Dealer had 50 all around. I guess they leave them slack so the trucks will ride a little better, maybe it helps sales, I dunno. Same dealer had a new crew cab Dodge 3500 dually on the lot that had the duals almost touching at the bottom. I bet it didn't have 30 psi in the tires. Anyway, I rather have them a pumped up a little tight rather than running a little slack and hot, specially in this 100 degree heat we're having. | |
   Location: Danielsville Georgia | Well I have had 2500/3500 trucks 30 odd years.80 front is dangerous if a blowout.Read the door jam sticker on max inflation FULLY LOADED.Its not needed in the front.80 on dually rears is very seldom needed.Weight is split 4 ways.I run 55 year on my dually with my three horse trailer and ran 70 rear with my old Hart LQ that weighed 9k empty.To each their own but I saw and have seen rapid wear at 80 psi empty. PLUS one harsh ride.I ran tire stores and then full service dealer service departments 30 odd years.Handled/repaired many many 2500/3500s gas and diesels.Never lost a tire on one of my trucks and sometimes got 90k out of a set. | |
     Location: Where the wind comes sweepin' down the plain... | Originally written by hounddog on 2010-06-28 9:36 AM
Well I have had 2500/3500 trucks 30 odd years.80 front is dangerous if a blowout.Read the door jam sticker on max inflation FULLY LOADED.Its not needed in the front.80 on dually rears is very seldom needed.Weight is split 4 ways.I run 55 year on my dually with my three horse trailer and ran 70 rear with my old Hart LQ that weighed 9k empty.To each their own but I saw and have seen rapid wear at 80 psi empty. PLUS one harsh ride.I ran tire stores and then full service dealer service departments 30 odd years.Handled/repaired many many 2500/3500s gas and diesels.Never lost a tire on one of my trucks and sometimes got 90k out of a set. You are right. A blowout on the front is dangerous. Period. 65psi, 80 psi, doesn't matter, still dangerous. And each to their own is right too. Had a 93 Dodge DRW came factory with about a cheap a tire as you could put one one...ran them 64,000 miles...they were a Firestone 6 ply that max load was 65 psi. Just pulled a set of Goodyears off of an 07 Chevrolet...82,000 miles. Only truck I ever had that wore funny at max psi was a Ford. Ran Michelins on that and at max psi got shoulder wear. Go figure. I run a lot of weight most of the time, and only a little weight other times. But I will always run max. And I have multiple trucks and trailers going most of the time. | |
      Location: Rocky Mount N.C. | Originally written by hounddog on 2010-06-28 10:36 AM
Well I have had 2500/3500 trucks 30 odd years.80 front is dangerous if a blowout.Read the door jam sticker on max inflation FULLY LOADED.Its not needed in the front.80 on dually rears is very seldom needed.Weight is split 4 ways.I run 55 year on my dually with my three horse trailer and ran 70 rear with my old Hart LQ that weighed 9k empty.To each their own but I saw and have seen rapid wear at 80 psi empty. PLUS one harsh ride.I ran tire stores and then full service dealer service departments 30 odd years.Handled/repaired many many 2500/3500s gas and diesels.Never lost a tire on one of my trucks and sometimes got 90k out of a set. I don't care, you'll not change my mind, no matter how hard you preach.... I'm getting old and grumpy, and it's hotter than a ---- ---- tom cat and I ain't about to lower my air pressure to what the truck door sticker says, ain't going to be driving nobody's mushy, squishy, sloppy feeling 50 psi half flat tire truck. (all that said in a mono tone voice with one big breath, sort like Mr. Hainy from Green Acres, LOL!!) Until the auto mfg's start building the tires that come on the trucks they sell, I'll run the maximum all the time. Ya'll stay in a cool spot today, good day to stay inside and practice our typing skills. Hounddog, how are you making out in this heat..??
Edited by retento 2010-06-28 11:29 AM
   Location: Danielsville Georgia | I don't always follow tire psi on the door except on FRONT tires.I have seen many many 2500/3500 with the center tread bald LONG before the outer/inner tread.80 psi on a dually rear is not needed unless FULLY LOADED.Thats a LOT of weight to load one to max and max air psi.With Chemo drugs its murder.The heat that is.Been working on my 5th wheel rv today.I get light headed in the sun.The heat isn't as bad.Getting ready to tank up on whole blood/platelets.Then load the dog up with me then to Charleston S.C. Visit a friend from grammer school.Then down the Atlantic side of Florida.Hope to end up at Smokey Joe's bar in Key West with a cold one.I get Chemo 5 days,one bag a day.Then off 23 days.Only issue is my blood counts drop way into the red zone.LOL Its hard to get away like this.I'm determined to go smell the ocean,play with the dog on the beach. | |
      Location: Rocky Mount N.C. | Been on that week on, three weeks off, Fluorouracil (5FU) deal in 1993. Don't know what was the worse, Chemo, Radiation or the cancer.... Having good thoughts for your speedy recovery!! Drive safe and get to the Key's before the oil slick beats you to it. I expect when it rounds the bend around Florida and catches the gulf stream, we'll be getting some of the "CRUDe" on the North Carolina beaches... Look out Ocracoke Island. http://www.ocracokeisland.com/ | |
   Location: Danielsville Georgia | No radiation with this type of Leukemia.Told radiation is rough.I was in remission 27 months.I spent 3.5 months at Emory University and had 6 week long 24/7 chemo's with different drugs.I came out of remission and spent 40 days at Emory.Now I need a bone marrow transplant.The chemo now is just to keep me in remission.Not a cure.I get a little bag of Decitabine for 5 days.I look good at 6'1 and 230,I feel OK.Not great but OK.Have yet to get sick from Chemo or anything else so far.Doctors are like Wow what a constitution. I did lose 55 lbs in the 40 days I was in last time.I didn't look good when I came home.Some good sleep and food brought me right back in about two weeks. | |
   Location: MI. | 70 in the front and 80 in the rear. I keep them rotated. They are wearing even.... | |
   Location: Harrisburg, PA | Originally written by retento on 2010-06-28 11:27 AM
Tire pressure and load follow each other. More load, more pressure, up to the maximum. Less load, less than max pressure. I hope we agree on this point.
Tires are designed to handle up to a maximum load. Unless you're always loading your tires to maximum rated load, maximum pressure is too much. If the tread wear is still acceptable doing this the only thing you're hurting is your suspension bushings and kidneys.
The truck manufacturer knows what the truck weighs and what it can carry. The truck's recommended tire pressure is based on more accurate information than a sidewall maximum.
Given that everyone here on this board is towing, it's not necessarily a bad practice. And the tires available for sale in the sizes that fit our stock truck wheels are generally built exactly for the truck applications. But it's definitely not the rule, and on many vehicles it's asking for trouble.
In theory the best way to determine tire pressure on radials is to use a pyrometer to measure tire temp across the tread width and adjust pressure to make it as even as possible. This ensures the inside, center, and outside tread are working as even as possible and you're not burning up any particular section. (This can also give you guidance on camber settings). I've not attempted this on a tow vehicle but basically put it under good work (say, highway driving) and take the temps as soon as you can slow and stop from that.
Dave
       Location: western PA | If the tread wear is still acceptable doing this the only thing you're hurting is your suspension bushings and kidneys. How is an extra 10 LBS of tire pressure going to damage a heavy duty truck? One trip down a rough road would do more harm. Our truck rides quite well at max tire pressures with no kidney problems noted. The truck's recommended tire pressure is based on more accurate information than a sidewall maximum. But it's definitely not the rule, and on many vehicles it's asking for trouble. ????? What kind of trouble? More tires are damaged and experience blowouts from under inflation than over inflation. The Explorer/Firestone debacle is but one example. The manufactures are interested in a compromise between ride quality and utility, and their recommendations reflect those interests. The higher the tire pressure, the less rolling resistance will be experienced and a lower opperating temperature will result. Heat will kill tires by delaminating the sidewalls and causing blow outs. In theory the best way to determine tire pressure on radials is to use a pyrometer to measure tire temp across the tread width and adjust pressure to make it as even as possible. This ensures the inside, center, and outside tread are working as even as possible and you're not burning up any particular section. This is not only a theory, but an actuality, commonly used on racing vehicles where the maximum adhesion is desired. Because many racing compounds are heat sensitive, the opperating temperatures are especially critical. The temp scans also point out the various suspension settings and wing loadings on cars equipped with aerodynamic assists. The air settings are critical to within one or two pounds pressure and can effect lap times. Most trailer owners aren't too concerned with optium cornering speeds. Based on my personal trucking experiences and apparently those of other posters in this forum, the temperatures and wear variances across the threads of maximum inflated tires, have not been an issue. We have had long tire life, reliability, no suspension difficulties or need for kidney transplants. Each owner has his own rig that differs from other owners. To suggest that we all have to use the same manufacturers' settings, would indicate there are no variances among the owners' equippment. Each tire brand, truck manufacturer, driving style, trailer type, and truck option, will change the needs from one owner to the next. One size doesn't fit all. | |
   Location: Danielsville Georgia | ell just darn! Your even a expert on tires,suspension and kidneys.I'll say it again 80 psi FRONT(usually,depends on tire) is HARD on a truck suspension.I ran shops and fixed them for a living.Saw more ball joints and bushings on bone jarring riding trucks then not.Try a lower pressure,then go MAX and test drive.If difference can't be felt then you'd never feel a scale 5 earthquake either. Too little air psi is dangerous.Too much is costly on tire wear and vehicle repairs.PLUS you don't get the full imprint of the tire on the road.Tires sitting straight up in the middle slide a lot easier then one with full contact. | |
       Location: western PA | Originally written by hounddog on 2010-06-29 12:45 PM
bone jarring riding trucks........... you don't get the full imprint of the tire on the road.Tires sitting straight up in the middle slide a lot easier then one with full contact. You obviously have had no experience with radial LT truck tires. If you did, you would realise your last comments have no verasity. When a radial truck tire is installed on a vehicle, not only is the entire thread area in contact with the ground, but the sidewall transitions are as well. In fact, by a visual inspection, most people cannot differentiate the shape of a radial truck tire, when the air pressures vary between 40 psi and 80 psi. At maximum pressures, the center is not elevated, leaving the sides off the ground, nor will the center thread support the whole tire in a turn. The very reason a radial tire offers superior handling over a bias ply tire, is the wider thread area and its carcass flexiblity that reduces thread squirm. Since you have never driven my truck, pulled my trailer, know what tires I use, know what I carry, and upon which roads I travel, you have absolutely ZERO personal knowledge, about how it rides, how it handles and how much maintenance it receives. I guess you didn't read or understand my last statement, which by the way, was not addressed to you. If you had, you might not have needed to try to shoot the messenger. "Each owner has his own rig that differs from other owners. To suggest that we all have to use the same manufacturers' settings, would indicate there are no variances among the owners' equippment. Each tire brand, truck manufacturer, driving style, trailer type, and truck option, will change the needs from one owner to the next. One size doesn't fit all." gac | |
| This has been a very informative thread to me and I appreciate it. Coincidentally, I took my 2005 F-350 diesel 4wd club cab long bed in to have the tires rotated and balanced today. They are 18 " Michelins. I didn't say anything to the tire shop where I had purchased the tires about my use of the truck. When I picked it up they had set the tire pressure at 70 all around. They did say (and it's true) that there was some uneven wear on the fronts. | |
   Location: Danielsville Georgia | Almost all my experience is with radials.Over inflated is over inflated and will wear in the center.I hear the in thing now is running tires at TWICE the advertised pressure.Why don't you try it on a long drive in this heat. I'm done with you and this site because of you.You interject in EVERTHING. I remember a time on this site before YOU. You'd argue with a brick wall. | |
   Location: Harrisburg, PA | Originally written by gard on 2010-06-29 9:50 AM
The case where running max tire pressure is a bad idea is lighter passenger cars. I'm talking about tires with 50psi max on a car recommending 31psi. Running at 50psi can deform the belting, the higher spring rate will reduce traction on uneven pavement, etc. It might not cause a blowout but it can cause accidents. The difference between light truck tire max pressure and door jamb recommendation is not as large as passenger cars. My point is that running max tire rated pressure is ok by coincidence in the case of light truck tires, and it does not imply that running max tire pressure is a good rule for motoring in general.
While light truck and LT radial tires are a different breed than racing tires, the pyrometer is still holds the answer. Your experience running max tire rated pressure has been good. I agree that tire carcass temperature is the critical factor for reliability and life. A pyrometer probably won't show big differences in temp across the width of the tire, but it could show how tread temps increase / decrease with tire pressure.
Now for those of us with TPMS, running max pressure is not as simple. My front IIRC have sensor expecting 65psi and it will throw an alarm if the pressure is above or below that. The rears are higher. To run 80psi all around, I expect I'd have to exchange pressure sensors, correct?
   Location: Harrisburg, PA | Originally written by gard on 2010-06-29 10:50 AM The truck's recommended tire pressure is based on more accurate information than a sidewall maximum. But it's definitely not the rule, and on many vehicles it's asking for trouble. ????? What kind of trouble? More tires are damaged and experience blowouts from under inflation than over inflation. The Explorer/Firestone debacle is but one example. The manufactures are interested in a compromise between ride quality and utility, and their recommendations reflect those interests. The Explorer/Firestone thing is important because it underscores the importance of correct tire pressure. Firestone blowouts were not just about a weaker tire, but in each case it was high speed driving in high ambient temps with heavy vehicle loads, and UNDERINFLATED TIRES. It's pretty safe to say that most all of the issues would not have happened if the driver had checked their tire pressure.Originally written by gard on 2010-06-29 10:50 AM The higher the tire pressure, the less rolling resistance will be experienced and a lower opperating temperature will result. Heat will kill tires by delaminating the sidewalls and causing blow outs. Overinflation very quickly diminishes in value w.r.t. rolling resistance. A little more is a little better, but a lot more is not. While the door jamb value might give up 0.5 mpg vs. adding 5 psi pressure, adding 10 or 20psi is worth nothing. | |
       Location: western PA | Dgeesaman, I agree with your comments. Mine were based on LT tires, being run at 80 psi. I don't recommend over inflating a tire, and yes, there is little value in less rolling resistance when the tire is being destroyed by over inflation. The owners of the Explorers were told to run their vehicles' tires at~<30 PSI, which as you have noted, was underinflated and caused sidewall blowouts. These pressures were condoned by Ford for ride quality, against the recommendations of Firestone. The unknowing vehicle owners could have been very prompt in their mainentance. However by following Ford's schedule, they set themselves up for the exact circumstances you've described. As I've tried to point out, each of us has different rigs and requirements. We all do things that work best for us. I and some others use one pressure. Others use different ones. The tag on the door cannot differentiate among our various needs, and offer the best recommendation for each of us. | |
Location: The Nederlands Europe | If you read everything from the tires like "max load xxxxkg at yyy kPa cold", or in lbs and psi, you can calculate the needed pressure with spreadsheet I made , in wich I use the European( most savest) equation, that I once got hold of. http://cid-a526e0eee092e6dc.office.live.com/browse.aspx/.Public/Car... in this map the spreadsheet . If it is all abacadabra for you , give me the details, besides the tire-specifications above mentioned, the Gross Vehicle weigt ratings of the trailer ( GVWR) and I will do it for you as an example. For the car I also made and translated a spreadsheet,navigate to it from the link above | |
Location: The Nederlands Europe | http://cid-a526e0eee092e6dc.office.live.com/browse.aspx/.Public/Caravans%20or%20trailers%20tyrepressure%20advice Here the linkable link , thougt it went automatically. But b ythe Ford Explorer/firestone affaire the American Tire-manufacturers discovered that they had used the wrong power in the universal equation ( 0,5 ) , and after the affaire they upgraded it to the european power of 0,8 wich comes to higher pressures at reduced loads. You could read next article about a new way of calculating and the comparison with the diferent used power-equation in America and Europe http://cid-a526e0eee092e6dc.office.live.com/self.aspx/.Public/tirepressureatreducedloads.pdf | |
