         Location: western  PA | There are a dozen brand names that will do the job. Generally, the larger the buffing pad, the slower the RPMs you will want. The better ones will have variable or multi speeds. Buffing generates a lot of heat, which is lessened by the lower speeds. There is a difference between a buffer and polisher, and depending on what you want to do, will determine which to purchase. A buffer is a heavy duty, high amperage machine, that is used with various compounds to smooth and erode uneven surfaces. Many double as sanders with the variable speeds, and most feature a circular action with large pads. If you want an applicator for waxing and polishing, there are many lighter duty machines available, that are specific for this application. Some even are 12v models and can be plugged into a cigarette lighter. These are available with circular actions, as well as random orbit models. The random orbit models excel in polishing, as most of the swirl marks generated with circular machines are eliminated. If you presently have a random orbit sander, buffing and polishing pads can be used to convert the sander to a polisher. Even though most are high speed (~12K OPM), their dual action and smaller diameter pads, keep the surface cool enough for polishing. So, if you want a heavy duty sander/ buffer, purchase a name brand, industrial, multi speed unit from many sources; big box stores, mail order, Internet etc. If you want a waxer /polisher, WalMart. KMart, auto parts stores, all sell inexpensive Chinese variants that will do well for a weekend warrior.  |
         Location: western  PA | Not being able to easily edit is a pain. I didn't answer your question about a pad for your drill. Yes they are available in small diameters and will help with polishing. BUT, most are small, poorly made bonnets, constructed of cotton or some cheap materials that quickly deteriorate. It would be a long and frustrating experience to use these on a whole trailer. It would take many to complete the job, and probably cost more than one good bonnet.  The better bonnets that are used for metal work, are made of lamb's wool. They last a long time and are washable.  The foam pads you see being used to buff out automotive paints, are for finer work, and are available in several stiffnesses depending on the particular part of the buffing that is being accomplished. They generally are not used on bare metals.  |
