Dexter Nev r Lube questions
BlazingCreekBar
Reg. Nov 2008
Posted 2010-05-05 7:42 PM (#119773)
Subject: Dexter Nev r Lube questions
I have a nail in one of my tires so I took it off today to take it for a patch.
My question is:
How much drag should be present when you spin the drum?  When spinning the drum should the drum spin freely?
To inspect the shoes I see that I need to remove the dust cap and then follow the instructions on the Dexter sites instructions.
So my next question is:
There is a small amount of thick greenish liquid in the area under the dust cap.
How much is normal? (I have about a teaspoon)  I have yet to remove the other wheels but will once I get back with the patched tire tomorrow to compare.
BlazingCreekBar
Reg. Nov 2008
Posted 2010-05-07 8:15 PM (#119888 - in reply to #119773)
Subject: RE: Dexter Nev r Lube questions
I had my tire patched while there I asked the mechanic "his" opinin of the drum adjustment.
He said at least a full spin to a spin and a half, should be good.
So I will go with that.
