Originally written by chill on 2010-05-04 8:34 AM
I have a 92'ish Sundowner Gooseneck trailer. Finally looking at replacing my GMC2500 (94) with something a bit newer. I am looking for a 2500, automatic with a V8 4X4, gas. I will likely haul a trailer only 1,200 miles a year and the truck will be used for short trips around town (hauling hay, wagons, tools, etc.) My questions are:
What gear ratio for my rear end should I be looking at? I need a work truck, my GMC is geared high and I have to put it in four wheel drive to start a wagon on clay ground (annoying). Is one particular brand showing its worth more than another? I will likely be looking for something with low miles and about a 2005.
The thing that really worries me is the clearance on my trailer. I have a 6 foot bed with a club cab now and have never had a problem. I would like to stay with the short box. The goose hitch should be placed where in realation to the axle? Recommended clearance from the hitch to the back of the cab is what?
Please weigh in with your opinion(s) and knowledge.
First off, what gears do you have in your 94? Since you stated you have to use the 4x4 for the wagon, I would guess you have 3.42's..... My opinion if you are not too worried about fuel mileage I would find something with 4.10 gears that way you will have more low end and will be less likely need to use the 4x4. This in some cases will use more fuel, but is much better on the engine and drivetrain. In plain english you are not having to work the truck as hard as you do with a smaller engine.
As far the short bed, I really can't help you there. I have never had room for a short bed in my farming needs. Just not enough room. There is a couple of companies out the make an extend gooseneck ball just for short bed truck.
