trailer wall attachment to floor question
Safet
Reg. May 2009
Posted 2010-04-30 11:18 AM (#119544)
Subject: trailer wall attachment to floor question
When I pulled the trailer mats out and washed the trailer, I noticed that the weld between the walls and floor is not continuous - that is - there are welds running down the length of the trailer, but it's not continuous. Is this normal, or should I be contacting the trailer company to have more welding done?
Thank you.
Edited by Safet 2010-04-30 11:19 AM
wyndancer
Reg. Apr 2007
Posted 2010-04-30 2:31 PM (#119554 - in reply to #119544)
Subject: RE: trailer wall attachment to floor question
Skip welding is very common. It really prevents warping due to thermal load being generated in a continuous bead.
Safet
Reg. May 2009
Posted 2010-05-02 11:14 AM (#119612 - in reply to #119544)
Is there any specification on how far apart the welds should be and how long each welded area should be? Thanks!
wyndancer
Reg. Apr 2007
Posted 2010-05-02 1:17 PM (#119616 - in reply to #119612)
Maybe a 3" weld with somewhere between a 3"-6" skip...depends on what the builder wanted though.
Posted 2010-05-02 6:22 PM (#119628 - in reply to #119544)
The amount of welds should approximate the strength of the material being used. Fabricators usually use prints and standards established by engineers. In auto body repairs, the welds are usually finished off and ground smooth for panel repairs.
