fresh water storage
memory
Reg. Jul 2007
Posted 2010-04-06 10:16 PM (#118525)
Subject: fresh water storage
Has anyone heard of having water storage under the gooseneck of the trailer. I think she meant between the supports.
Safet
Reg. May 2009
Posted 2010-04-06 11:27 PM (#118530 - in reply to #118525)
Subject: RE: fresh water storage
Do you mean under the gooseneck and in the truck bed?
Paracadista
Reg. Oct 2009
Posted 2010-04-07 3:22 AM (#118531 - in reply to #118525)
I have seen a manufacture that is using the tubular steel frame for fresh water storage, which I believe included the gooseneck. I was at a trade show and he didnt have my full undivided attention, so I'm not positive of that.
Tresvolte
Reg. Feb 2008
Posted 2010-04-07 8:48 AM (#118542 - in reply to #118525)
There was a post on here somewhere somtime back about water storage that someone had made out of 4" pvc pipe between the crossmemebers. I have also seen some trailers that have water tanks on on the gooseneck wall. Keep in mind...storing water out on the gooseneck will add directly to your tongue weight...very little of that weight will transfer to your axles on the trailer.
nobodyimportant
Reg. Jan 2010
Posted 2010-04-07 10:56 AM (#118553 - in reply to #118542)
Originally written by Tresvolte on 2010-04-07 9:48 AM
It will also be shifting weight which will cause more stress at the hitch. Also pvc isn't ment for water storage only sewage.  The chemicals can be harmful.
memory
Reg. Jul 2007
Posted 2010-04-07 4:15 PM (#118566 - in reply to #118525)
Yes, I was talking between the supports.
Posted 2010-04-07 4:27 PM (#118567 - in reply to #118525)
PVC piping has commonly been used for cold water supplies in houses for years. You can quickly build a reservoir using 4" or 6" piping. Most GN rigs can accommodate a couple extra hundred pounds on the pin. If you have the room, this seems like an ideal location.
http://www.dannylipford.com/diy-home-improvement/plumbing/are-plastic-water-pipes-safe/
horsecamper
Posted 2010-04-07 5:32 PM (#118569 - in reply to #118525)
memory,  Have you considered a hay rack?.  I mount water tanks in my hay racks.  It's an easy 48 gallons of water with good water pressure. Easy fill from the ground. I just use it for the horses so I use the white tanks, but if I wanted it for people, I would buy a dark green or black tank so that nothing would grow.  Another advantage of storing water in this area is that the weight is over the axles.
memory
Reg. Jul 2007
Posted 2010-04-07 6:25 PM (#118571 - in reply to #118525)
I have water storage already. Someone just asked me about putting water storage under the gooseneck.
