De-winterizing
Sheryl
Posted 2010-03-26 11:54 AM (#118034)
Subject: De-winterizing
I plan to de-winterize this weekend or next.  I have an anode rod to replace the drain plug in my water heater.  There is a build up of "crud" in the hole where it goes.  What should I use to remove this?  Is it harmful to my water heater?  Thank you.
BlazingCreekBar
Reg. Nov 2008
Posted 2010-03-26 8:02 PM (#118041 - in reply to #118034)
Subject: RE: De-winterizing
The crud is most likely the left over plumbers thread seal from the old one.  Just wipe it off.  If it is white bubbly hard residue that could have been corrosion from a leak.  Scrap it off.
I would flush out your tank with a garden hose.  I used a female plastic hose mend from HD and attached a length of 3/4 clear tube I had lying around so I could get the water inside the tank.  As I was flushing the tank I took another length of the tube and created a syphen to vaccume the bottom out (worked like a charm) I was amazed how much sand came out when I did that.
When your ready to reinstall the new anode just coat it with plumbers thread seal and tighten like a spark plug  No need to crank it with all your might.
I use the bottle brush style wire brushes and reach into the flame chamber and then blow compressed air to get all the rust out of there.
I gently brush all the fittings and connections and then air gun everything off.  I do the same for the Refer.
The first light of the season is tough run the stove for a few minutes to get the propane thru the lines.
