Location: Ohio | Good Evening: Two months ago while driving my truck, F150 - 2001, it started to smell like something was burning. The truck stayed with the mechanic for a week. He couldn't get it to do the same for him. Yesterday I'm running errands and the smell starts. A mile down the road the engine starts to labor and white smoke is coming from the front left wheel. I called AAA to haul the truck to the mechanic. There's evidence of over heating but all parts are working. Forgive me if I describe this incorrectly, the piston in the caliper is working fine and they can't find anything really wrong. Nothing is sticking. He called the Ford dealer about any parts recalls. Nope. Does this sound familiar to anyone? Any suggestions? This old girl doesn't want to end up stuck in the boonies pulling my horse trailer. The mechanic has kept our various vehicles running for over ten years. He's a decent guy. Thank you. I'd appreciate any assistance on this. |
    Location: Minneapolis, MN | The truck is 9 model years old. I really think Ford doesn't have to do anything about it, but quite often they see repairs that independent mechanics don't.
I'd probably replace the caliper. Change the brake fluid.
Do you drive with two feet? One on the gas and one on the brake? Just asking'...some people do and don't realize it. |
    Location: Ingalls, Ks | Have had that happen on a Chevy before. If all the rest of the brakes are functioning properly my guess would be to replace the rubber line that goes from the frame to the caliper. What happens is the inside of the rubber line will start to come apart and it creates a "check valve" effect. You can apply the brakes and they work fine, but it ends up trapping the fluid where the line is collapsed and it can't release. It's not that expensive and I've had it happen twice. Oddly enough left front both times. |
   Location: Harrisburg, PA | Originally written by 3horse on 2010-03-19 9:48 PM
I would ask if the brake shims need replaced. These are smooth metal plates that support the brake pad, and when they get rusty they might cause the brake pad to stick and drag against the brake rotor.
I agree about the fresh brake fluid. If the brake got that hot it needs done anyway.
David
   Location: Minnesota | It's very possible the caliper stuck, and after it cooled down would release. Another possible is a sensor for the anti-lock might have stuck, which could engage just the one brake. I know it's expensive, but I would recommend replacing both front calipers and definitely the brake fluid. |
    Location: Florida | Your caliper guide pins may need replacing or just lubricated after a good cleaning. Not one of fords strong points. General rule is to inspect yearly. I am doing all mine this week. Some just replace the caliper bracket. More information here than one will ever need :) http://www.thedieselstop.com/forums/f122/
Edited by BlazingCreekBar 2010-03-20 5:06 PM
   Location: Arkansas | We had a sticking piston but the root cause was a collapse of the liner of the front brake line servicing it. Replaced piston and brake lines and all has been well 3 years and counting....good luck and keep on til someone fixes it, cuz it sure is not your imagination!! |
    Location: East London South Africa | I agree with 301 Duster...replace the flexable pipe between the caliper and the Chassis...its happened to me before as well. to be safe replace both sides...they should not be expensive..... and replace the fluid as well. |
Location: Ohio | Thank you to everyone that responded. In answer to one person asking if I was a two footed driver. No, that one I don't do. I've been behind two footers and its maddening.
Thanks again and I'll let you know what happens. |
  Location: TEXAS | My wifes F350 did this, what had happened was I was out of town, and the front brakes got done and when they put the calipers back on they accendently put a twist in the rubber line, he truck would only do it when turning tight and it would kink the line. untwisting the line took care of it. but I replaced them just to make sure they did not have any undue stress on them |
