generators
JcNhEmI
Reg. May 2009
Posted 2010-02-24 2:43 PM (#116973)
Subject: generators
what kinds are good. and can run LQ?
Are they nessecary(sp)? I"ve heard of people not using them on LQ trailer?
is there any place to buy used ones?
 Thanks!
BlazingCreekBar
Reg. Nov 2008
Posted 2010-02-24 6:06 PM (#116980 - in reply to #116973)
Subject: RE: generators
When I purchased mine it was based on starting my AC and being able to be lifted.
http://www.wisesales.com/YamahaEF2400iS.html
I am very satisfied with this model.  It is two years old and starts the first pull every time.
We run it in the am for coffee.  On hot days after a long ride we cool off in the AC have hot dogs inside, shower and then emerge refreshed with an adult beverage :)
Posted 2010-02-25 8:41 AM (#116987 - in reply to #116973)
I also have the Yamaha EF2400is.   It weighs 70 lbs so it's luggable.  Most of the 3000watt units all weigh in around 130lbs.  The 2400 puts out 2400 watts which will start most A/C units.  It is quite at 53db. and pretty fuel efficient.
The down side is that you can't run several larger electric items at the same time. For example, probably have to turn off A/C while you run Microwave.
If you are going to mount it and leave it put, Get the 3000 watt unit.  Honda or Yamaha both make great invertor type generators.  If you want something that you can lift into the truck or use around the farm that is a little more portable, I think the EF2400 is a good sized unit.
A few bits of advice.
Buy a quite generator. Something around 52-54db. DON"T buy a unit that runs at 60-70 db.  Your camp neighbors will hate you.
Buy an INVERTOR generator. They produce CLEAN electricity.  Light bulbs don't really care about clean or spikie electricity, but laptop computers, flat screen TV's, Microwaves anything with electrical circuitry will care and will last longer with clean power. Most of the cheaper generators that you will find, are not invertor based.
nobodyimportant
Reg. Jan 2010
Posted 2010-02-25 1:15 PM (#117000 - in reply to #116973)
Ditto to what painted horse has said.  Stick with Honda or Yamaha.  They both are quiet and about the same as far as features.  Whichever one you can get the best deal on is the one I would recommend.
barry
Posted 2010-02-25 3:57 PM (#117010 - in reply to #116973)
I have the Honda EU3000. Wt ~130 lbs I just put in a weekender pkg over the cold crappy winter. The other day the generator ran a 1500 watt electric heater and 1000 wt microwave at the same time plus the converter running all the lights. Figure the AC won't pull more than the heater. Little heavy but it has 2 easy to hold handles. 2 ppl can carry it anywhere (theft???) and me (a guy) can sit it in and out of the 1st stall through the escape door by myself. So far I am pleased.
lesliemal
Reg. Sep 2007
Posted 2010-02-25 4:27 PM (#117012 - in reply to #116973)
I wanted to get the Honda 3000 but my honey talked me into getting the Honda 2000 Companion because it only weighs about 47 lbs. It is very easy to start even though it does not have the electric start. I plan on getting a second Hoonda 2000 and link them together to have enough power for the AC. Even if honey does not go with me, I can pick up the 47lb units. There was no way I could pick up the 130lbs that the 3000 weighs. From what I understand I should have more than enough power with the two units put together. I found the best deal through Wise Sales as well.
Edited by lesliemal 2010-02-25 4:28 PM
brushycreekranch
Reg. Jun 2006
Posted 2010-02-25 6:18 PM (#117015 - in reply to #116973)
500100100100100
I bought this for my run around trailer.
Print this page
See additional images
 ETQ 3500WT Inverter Generator
Select Quantity, then click "Add to Cart"
The item is available ONLINE only
 Home or Business delivery: Delivery: $898.44
Shipping Included
#247445
<script type=text/javascript>
Overview
The IN3500i inverter generator generates 3500W of max power, using a 5.4 HP heavy duty OHC motorcycle engine. It produces all this energy weighing only 69 pounds. Outlets included are (1) 120V 30 Amp L5-30R twist lock outlet, (1) 120V 20 Amp GFCI duplex outlet. This makes the IN3500i one of the few clean inverter power generators that can run your RV air conditioner without the need of parallel power kits. The IN3500i features ETQ’s Inverter Power Technology, which delivers clean power suitable for computers and other electronics with a THD (Total Harmonic Distortion) less than 3%. It offers 5/3.5 hour run time at 50/100% loads. Our unique auto throttle feature, which lowers RPM to idle speed in between power usage to provide better fuel economy, lowers noise and extends engine life. The unit is also neighbor friendly and quiet at 60dB at 23 feet. Our inverter generators come with a one year warranty and meet all US park regulations.<script type=text/javascript>
Specifications
  • 3500 watt max
  • 3250 watt rated
  • ETQ Inverter Power delivers clean electricity with low THD waveform under 3%
  • 5 hours at 50% load
  • 3.5 hours at 100% load
  • 1.5 gallon fuel tank
  • (1) 120V 30 Amp L5-30R twist lock outlet
  • (1) 120V 20 Amp GFCI duplex outlet
  • (1) TT-30 included
  • Easy pull recoil start
  • 149.5 cc
  • 60 to 65 dB rating<script type=text/javascript>
  • share Top of the page Bottom of the page
    brushycreekranch
    Reg. Jun 2006
    Posted 2010-02-25 6:20 PM (#117016 - in reply to #116973)
    500100100100100
    Bought it from samsclub.com
    liv to ride
    Reg. Jul 2007
    Posted 2010-02-25 7:09 PM (#117019 - in reply to #116973)
    I have two Honda 2000 that I can link together with a cable. I think they are wonderful. They start easy, seem to run forever, and you can carry them with one hand. They'll run my AC all night on one tank of fuel and then some. Last winter when we were without power for three days because of an ice storm they ran my refrigerator/freezer, TV, VCR , and computer. Only wished I had bought them sooner. They have more than paid for themselves.
    Dunagain
    Posted 2010-02-27 10:10 PM (#117081 - in reply to #116973)
    So Honda eu2000i will NOT run a 13.5 Ac unit? I have a small LQ (4' SW). I suppose I could turn off the AC when I have to run the microwave. I thought it would be enough. The 3000 is too heavy.
    Posted 2010-02-28 12:15 AM (#117084 - in reply to #117081)
    Originally written by Dunagain on 2010-02-27 11:10 PM
    The Yamaha EF2400 should start and run your AC. It weighs approx. 70#. You got to have generator enough to get the appliance started. An RV, AC takes 1500 to run, but it takes 2200 to start it......
    Wattage Chart
    CategoryApplianceRunning Wattage RequiredSurge Wattage Required at Startup
    Household/RVCoffee Maker17500
     Dishwasher: Cool/Dry7001400
     Electric Fry Pan13000
     Electric Range: 8in. Element21000
     625W Microwave625800
     Refrigerator or Freezer7002200
     Automatic Washer11502300
     Electric Clothes Dryer18005750
     Furnace Fan (Gas or fuel oil): 1/8 HP300500
     Furnace Fan (Gas or fuel oil): 1/6 HP500750
     Furnace Fan (Gas or fuel oil): 1/4 HP6001000
     Furnace Fan (Gas or fuel oil): 1/3 HP7001400
     Furnace Fan (Gas or fuel oil): 1/2 HP8752350
     LightsAs indicated on bulb0
     Radio50-2000
     Sump Pump: 1/3 HP8001300
     Sump Pump: 1/2 HP10502150
     Color Television3000
     RV Air Conditioner: 13,500 BTU15002200
     Room Air Conditioner: 10,000 BTU15002200
     Central Air Conditioner (for 2200 sq. ft. home*)10,00011,250
     Small Appliance2001700
    Contractor8in. Bench Grinder14002500
     Pressure Washer: 1 HP12003600
     7-1/4in. Circular Saw14002300
     Electric Chain Saw: 14in. Bar, 2 HP11000
     10in. Table Saw18004500
     Drill: 3/8in., 4 Amps440600
     Drill: 1/2in., 5.4 Amps600900
    Industrial MotorsSplit Phase: 1/4 HP6001000
     Split Phase: 1/2 HP8752300
     Capacitor Start Induction Run: 1/3 HP7201300
     Capacitor Start Induction Run: 1 HP16004500
     Capacitor Start Capacitor Run: 1 1/2 HP20006100
     Fan Duty: 1/6 HP550850
    Farm EquipmentElectric Fence: 25 Miles25000
     Milk Cooler11001800
     Milker (Vacuum Pump): 2 HP10002300
     Portable Heater (Kerosene, Diesel Fuel): 50,000 BTU400600
     Portable Heater (Kerosene, Diesel Fuel): 90,000 BTU500725
     Portable Heater (Kerosene, Diesel Fuel): 150,000 BTU6251000
     Battery Charger: 15 Amp3800
     Battery Charger: 60 Amp with 250 Amp Boost1500/57500
     Battery Charger: 100 Amp with 300 Amp Boost2400/78000
     Electric Welder: 200 Amp AC90000
     Electric Welder: 230 Amp AC at 100 Amp78000
    ComputersDesktop600-8000
     Laptop200-2500
     Monitor200-2500
     Fax600-8000
     Printer400-6000
    BlazingCreekBar
    Reg. Nov 2008
    Posted 2010-02-28 6:06 AM (#117086 - in reply to #116973)
    I have the Yamaha 2400  It does run the AC. We do not have a microwave. I can not speak to that.  We do run a coffee maker and it can be run at the same time as well as the pump with the ac.
    It took me about two trips.  The first time I thought I made a mistake buying this model.  The second trip and so it all worked out.
    I like the portability and size.  If I wanted unlimited power I could always bring my Generac electric start that I use for my House back up.  But noooo this model works just fine.
    I will be honest you have to be carefull.
    If your batteries are low or you have another appliance running the AC will not start and the gen will pop its overload switch.
    When I want AC I run the Gen for a few minutes.  In other words I don't turn on the gen and then flip the ac switch.  I will generally place the ac into fan mode for a few seconds and then back the thermostat into it.  I also make sure any of the extras like motorized vents are in the off position.
    I am also careful to ensure the refer is on propane only as it will automatically switch to the generator if you are in the auto mode.
    Once it starts everything else as normal.
    We do not have a microwave. So I can not speak to that.  We do run a coffee maker and it can be run at the same time as well as the pump.
    sweetas
    Reg. Dec 2009
    Posted 2010-03-01 8:05 AM (#117123 - in reply to #116973)
    I am surprised no one has mentioned an Onan generator. I will admit I don't know much - but I have heard good things about them for reliability and quiet operation. Maybe someone else can comment more?
