       Location: western PA | The cabinet dimensions in a LQ can vary just like a kitchen installation in your home. There are basic averages that are used, but the important thing is that they can be altered to fit your needs. If you are tall or short, the heights can be altered to what is most comfortable for you. The depths can be varied as previously noted, depending on the installed equipment and the interior width of the trailer. If you install stock cabinets, they can usually be modified to your interior. If you make your own, it's easier to fit each irregular dimension. |
