       Location: western PA | My wife and I were kicking around ideas, of what features would influence the purchase of a "run around trailer". This type of trailer, we would describe as a non camping, non showing, alternative trailer used for trips to the vets, trainers, trail rides etc. It would be used for quick day trips, for one or two horses, instead of hooking up to a longer, larger, GN LQ. The basic trailer we are considering, would be a two horse, BP, slant load with a minimal tack area in the front. The tack area should be large enough for buckets and water storage, along with a saddle or two and tack. It would not have to be large enough to be used as a dressing room. The back door would either be a one piece stock type of tailgate with access, or a two piece door design with no center post. There would be no rear tack area in the left rear, only open flooring. Ideally it would be 7' wide and 7 1/2' high, not sure about the length, but as short overall as practical. It would have to have a front stall escape door, and a door for the tack area. It would have conventional siding with drop down windows on both sides and a slider in the tailgate. Conventional overhead vents would be utilized. Interior and exterior aux lighting would be powered by a stand alone battery, in addition to being supplied by the truck's output. It could feature 3500# axles, and 15" tires of a "D" range. A Galvaneal, Galvalume or aluminum construction would be specified, no soft steel. Depending on the construction, either a treated wood or aluminum plank flooring would be used. I've never seen a trailer built to these specifications, and wonder if a custom one could be built. I would be most interested in what you folks would consider necessary, for your "run around", if you wanted one. BOL Gard |
    Location: Iowa | I'd probably do just what you desribed above gard. Simple, yet very practical. I don't have a LQ trailer. I have just a simple featherlite 3 horse GN with a dressing room & a ramp. I can take out the partitions to haul mares and babies or move people. So I won't be needing anything else. But.....If all I had was a big LQ I'd be looking for a smaller trailer for just simple hauling. |
   Location: Mena, AR | I have the ideal run around trailer a 2000 Bonanza 7 foot tall 2 horse slant stock combo with a dressing room with a swinging gate in mint condition. I can haul 12 foot panels in it when the dressing room gate is open. I can remove the stall divider by my self or put it back on my own. It has a swing door on back and is great for hauling mares and a foal. Long tongue for easy backing, wood floor that will be easy to replace when needed. Easy to haul, was inexpensive, bought used, looks great. |
     Location: KY | I use a Delta stock trailer, gooseneck 16' box, steel with wood floor, plenty of room in the neck for stuff, cut gate in the middle so can haul 4 horses easily; or open the gate and haul lawnmowers, or haul buggy and one horse, very useful trailer. I think it is easier to hook up than the bumper pull I used to have.
Edited by rose 2009-12-19 9:35 PM
      Location: Rocky Mount N.C. | That 7 foot wide and 7 1/2 foot tall is going to be scarce.... Something like this may be close to what you're lookin'...?? http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=208764 OR..... Have someone like "Double D" build one as you like it... Send a PM to DD_TrailerMan
Bartley Heath bartley@DoubleDTrailers.com Buy Factory Direct at DoubleDTrailers.com |
  Location: Southern Il | Dont't know what you are wanting, but we have a two horse 4-star bumper pull, only we extended the tack compartment under the mangers by 20 inches(or whatever space one might need) and have a tack door on each side of the trailer. We can put our saddles, tack, and buckets in there with the extra room. It's a short trailer we can get into the smallest of trailheads or park alongside country roads. The divider swings over or can be removed. If we had to give up our LQ trailer or the two horse, the LQ would have to go. Love this trailer! |
    Location: michigan | I'd want a 2 hr GN with a minimal DR for a saddle or two. I have been considering such a thing myself. |
    Location: Iowa | I bought this little two horse for my daughter. Its great, not too big, not too small. Ok, I guess I won't show you a picture. It won't let me download because of the size. Sorry
Edited by sinful 2009-12-20 6:14 PM
       Location: western PA | Since my original posting, I've done some more research and received further information. We've also amended our requirements to delete the escape door. There are several companies building trailers already close to what we want. And thanks to Dave at Tobruk Trailers, I learned that both Merhow and Cherokee trailers have models that could be adapted to our specifications. I went through the HTW trailer for sale lists, always my first choice. I found several models that were close, and some features by various builders that really stood out. Here are a few samplings. http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=227353 Apparently this is a new S/D "Sportman" model. It is appealing but lacking in height. I haven't checked with a S/D dealer to see if a 7 1/2' version could be ordered. The features I particularly like are the windows, and the swing out saddle rack from within the forward tack room. It has the dual rear doors with no post. http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=234099 This trailer is by Eclipse, a company of which I am unfamiliar. They are located in OH, which is right next door. They have several models; this particular one apparently is the low end model. Their web site indicates fancier versions with rear windows, more goodies etc. Their trailers are 7 1/2' feet high, one of my requirements, and again has the double rear doors. I don't like the saddle racks as well as the S/D. http://www.horsetrailerworld.com/home/trailerdetail.asp?ID=230239 This trailer is built by Eby, which is highly noted for well constructed equipment. They are located in both PA and OH, and advertise that they can custom build almost anything you need. This one looks a little longer than I want, but has the height and no center rear post. One more feature I learned of, during my hours long search through all the 1300 + two horse trailers presently being advertised, was one company had a moveable tack/bulkhead wall that can be opened. I had a stock combo like that and it was useful when carrying longer items. I can't remember the manufacturer that offered that option, but it would be a feature to pursue. The bottom line is that it looks like we will, be able to have a trailer built to our needs. It won't be large or fancy, but it can be just what we want. We have an Equine Affair coming up in April in OH. By then we should know all our requirements, and can look at the many builders that usually present their wares at the show. Gard |
  Location: Zionsville, Indiana | Gard, it looks like you discovered that an escape door in front of the first stall doesn't work in a two horse this length due to the axle placement. The Eclipse trailer you found on HTW is available in an even lower priced model, and is available with a hinged divider wall as well as all the other things you mentioned. The one thing that you did NOT mention is something I think is the best thing to happen to horse trailers in recent years - "Rumber" rubber flooring. I definately would add that to my list of requirements for this Runaround (or any other) trailer. Unlike rubber matting or even Werm flooring, it has a surface that is not slick when wet or used without bedding. In an emergency or for a short run, you could skip the bedding. |
Location: Stephenville TX | Hart Trailers builds the perfect Run-Around Trailer, and Stephenville Trailers has 3 in stock. It is called a Short-Go and you really need to check it out. www.stephenvillvilletrailers.com Ask for Ty |
       Location: western PA | Would like to check out the Harts. The Hart home page and your web site had no mention or photos of a BP "Short-go". |
 Location: Aiken, SC | Guard, It is no problem to build the Sundowner Sportman 7'6" tall. Turnaround time right now is 6 -8 weeks on non LQ's. |
 Location: Aiken, SC | The movable/removable tack wall is also an option available on the Sundowner Sportman you were looking at. |
  Location: Virginia | The only Short Go trailers I see on that website are 3H GN. Gard said he was looking for a 2H BP. Am I missing something on the website that was linked to? |
       Location: western PA | Thanks Gary. According to the Hart web site, the "Short-go" trailer is a GN, not a BP. Their BP trailers are listed as "Medallion" and "Ultimate". Their "Short-go" model is not at all what I'm searching for. I've been having fun shopping, something I've not done in a while. One problem is the lack of accessibility for certain brands in my North Eastern area. We have few local dealers, but I'll settle on a day's drive, which includes many more states. Fortunately there are many interesting makes and models that can be modified. The 4 Star BP trailers look as well built as the GN models. I can't wait to inspect all the interesting brands in person, and compare their build quality and specifications. It's much easier to look for a pure trailer; one not encumbered with a LQ and frills. Thanks again, Gard |
 Location: Aiken, SC | Not sure how far you are from Kittanning PA but Altmyers sells both Sundowner and 4-Star. http://www.altmeyertrailers.com |
       Location: western PA | When I pulled up the dealers lists, I found out that Altmeyers was a dealer of both brands of which I was interested. They are only about two hours away and would be our closest dealer. sundownerofaiken, thanks for that and all the other info you have been providing. Gard
Edited by gard 2009-12-22 11:50 AM
    Location: Lockport, Illinois | I drove 500 miles to buy a used 4Star from Altmeyers, they are great to do business with, I would drive 500 miles again to buy another trailer from them. Good Luck. |
| i thought i had the ideal run around til i got caught......now she had the trailer too |
Location: Virginia | I've looked at the SD Sportsman as well as the new 737. They are nice little trailers. Yes, the one I saw was a 7 1/2' tall trailer. It even included the spare tire. The 737 (I think that is the right #) is the same trailer as the Sportsman except it has slats on the rear instead of windows, and the rear gate was a stock type. My only gripe is that there doesn't seem to be large enough window openings for good ventilation, and there aren't any bars to allow for the windows to be dropped down when traveling. |
     Location: Corpus Christi, Texas | My Hart medallion is what I would consider the ideal runaround, except that it is not 7 ft wide. But it does open up completey with no center divider (if the rear tack is folded) ..The front tack is a fair size and I have installed a gridwall storage system to help me organize my mountain of must-haves. wtih the rear tack folded I can carry 30 bales of hay in the back.. More if I was doing the stacking myself, and it is big enough to accomodate most large furniture items for the occaisional move.. |
  Location: Edmond OK | I have a two horse bumper pull W&W trailer. It does have the stock sides but is 7 tall and 7 wide with an escape door (no mangers), a large dressing room. I think several manufacturers have something you might like. I love my trailer. I have hauled furniture, appliances, hay - square and round. Plus before I bought my gooseneck LQ, I had a truck camper and I had room in the dressing room for all my camping stuff and three bales of hay plus my friend's stuff too. It sure is a handy trailer. I would never get rid of it! I've had it since 2000. |
