problems with drop leg jack
ccook
Posted 2009-11-14 6:14 AM (#113155)
Subject: problems with drop leg jack
I have the 12k spring loaded jack on my gooseneck that i am having problems with, I started to get hard to crank.  NOw i can't crank it all.  I greased the gears this year.  The gears look ok.  Looking for a resolution to fix it before I have to buy a new one.  I bought the trailer used and its a 93' soft touch gooseneck.
Thank you :)
Posted 2009-11-14 9:48 AM (#113161 - in reply to #113155)
Subject: RE: problems with drop leg jack
The gears are only one part.  There is a screw (that the gears turn) and nut inside the leg.  You'll have to extend the jack till you see a hole through the leg to the screw.  Look at the side of the stationary part of the leg.  There is a hole that is blocked by the moving part of the leg.  Extend the leg till the holes align.  Then oil the screw.
ccook
Posted 2009-11-16 3:04 AM (#113215 - in reply to #113161)
I will try this first, thank you for your help!
