Fridge too cold
laurie
Reg. Jun 2004
Posted 2009-11-07 9:53 AM (#112885)
Subject: Fridge too cold
10010010010025
I have a new to me trailer that I have used a handfull of times. This last time I used it everything was froze in the fridge. It was running on 110V and it has a seperate freezer area. Any ideas what to check for? I believe it is a norcold 7 years old
Laurie
mingiz
Reg. Jul 2004
Posted 2009-11-07 10:03 AM (#112886 - in reply to #112885)
Subject: RE: Fridge too cold
Can't you turn the thermostat down on the fridge. Mine is only set to 2 if I go to high it will freeze everything...Mine is a 2.7cuft w/freezer with a range of 1 to 4 on the switch.
laurie
Reg. Jun 2004
Posted 2009-11-07 5:01 PM (#112890 - in reply to #112886)
10010010010025
I will check but I hadn't had a problem before and nothing was changed.
mingiz
Reg. Jul 2004
Posted 2009-11-07 6:02 PM (#112892 - in reply to #112885)
I just replaced mine. It's a norcold also. When the other died it was 9yrs old and it just wouldn't cool...I had a Rv guy check mine out. Good Luck..There not cheap... You can check out the Norcold website for trouble shooting...
http://www.gasrefrigeration.net/norcold_manuals.htm
Edited by mingiz 2009-11-07 6:05 PM
laurie
Reg. Jun 2004
Posted 2009-11-08 8:16 AM (#112910 - in reply to #112885)
10010010010025
I mispoke. It is a Dometic and I didn't see anyplace to adjust tempature.
Dunoir
Posted 2009-11-10 11:19 AM (#112987 - in reply to #112885)
50010025
I find that the colder it is outside, the better the fridge works.  I have the 3.0 size and it has temp guages from 1-5.  I usually leave it on 5, but if it's 40 degrees or below at night, I have to adjust it down.  Plus the longer the trip and the longer the fridge is on, the colder it will get. I prefer to keep lettuce in a cooler as it freezes quite easily
Candy girl
Reg. Apr 2006
Posted 2009-11-10 3:15 PM (#112997 - in reply to #112910)
My Dometic doesn't have a dial or thermostat, per se, but there is a button on outside front that adjusts the temp.  Maybe that got bumped up higher than before.
Edited by Candy girl 2009-11-10 3:19 PM
