TV Antenna
Gone
Posted 2009-10-01 7:36 PM (#111329)
Subject: TV Antenna
10002525
Ok....Our trailer hd tv works in our house but not in the trailer. Thinking maybe the trailer antenna isn't working due to....? The antenna appears to be hooked up and fine. Can someone give me some clues as to why????
longearsrule
Reg. Apr 2006
Posted 2009-10-01 9:35 PM (#111333 - in reply to #111329)
Subject: RE: TV Antenna
100100100
You may need a converter box. I had to get one to put in my trailer. The tv was a new one but I guess maybe without an hd antenna they won't work.
genebob
Reg. Nov 2007
Posted 2009-10-01 10:21 PM (#111337 - in reply to #111329)
Check if the booster for your antenna is on. It should be located on the panel where you attach the cable. I didn't know about it until I was at the dealers getting my elec. jack installed. Another customer had your same complaint and dealer showed her (and me) where it was. It worked instantly.
Check fuses also.
Edited by genebob 2009-10-01 10:22 PM
Gone
Posted 2009-10-02 6:42 AM (#111343 - in reply to #111329)
10002525
Booster is on and we have a converter box......frustrating.
soundhorse
Reg. Aug 2006
Posted 2009-10-02 7:07 AM (#111345 - in reply to #111343)
Have your checked every connection? How many miles are you from the transmitting towers? Usually 65 miles is the limit for a antenna used for residential. In the right spot it is about 50 miles is the limit for the batwing type for RV use
genebob
Reg. Nov 2007
Posted 2009-10-02 10:39 AM (#111348 - in reply to #111329)
Another thought, do you need to program the tv? Sometimes if they are without electricity for a long enough period they lose their programing. If it is already HD you shouldn't need a converter box.
Edited by genebob 2009-10-02 10:41 AM
flyinghfarm
Posted 2009-10-02 10:53 AM (#111350 - in reply to #111329)
1000100100
We have the batwing antenna style about 9 years old.  Got a smaller flat screen TV for the LQ.  After the digital switch was concerned about needing a converter box.  But, hook it up, turn on the booster, do a channel search, and it works.  So it must have a digital tuner.  The channel search, lists how many digital channels, and how many analog channels it is picking up.  Are you in a fringe area for reception?  Could it be that there is just not a strong enough signal?
