Showering in front stall
perk2754
Reg. Oct 2007
Posted 2009-09-09 7:08 AM (#110462)
Subject: Showering in front stall
I just bought a propane camping shower and want to set up a make shift cowboy shower in the front stall of my slant load.  What do folks usually use on the floor, if anything, to help drain the water? I've thought about buying a washing machine overflow pan and connecting pvc pipe to drain it out the back door.  I also like to haul with shavings in the back two stalls and can visualize a big mess if I don't drain the water somehow and just let it hit the floor.  I'm not really keen on drilling holes in the floor of my trailer  but I guess I could.
D sq
Reg. Feb 2007
Posted 2009-09-09 7:25 AM (#110463 - in reply to #110462)
Subject: RE: Showering in front stall
If you have a lot of shavings, and don't want them wet. get the shower pan, you can cut a a 1 or 2 inch hole in the floor. It won't hurt the strenght of the floor. Put a short tube to go through the floor so the water won't drain out under the pan. I would recomend a regular shower pan, rather than a wash machine pan. The shower pan would have more strenght, taller sides than a wash machine pan
IcePonyGoddess
Reg. Nov 2006
Posted 2009-09-09 9:26 AM (#110474 - in reply to #110462)
500100100252525
IcePonyGoddess
Reg. Nov 2006
Posted 2009-09-09 9:29 AM (#110475 - in reply to #110462)
500100100252525
I used a new ...clean muck bucket. I also got some PVC and make a shower curtain frame, hung that and use it as a shower.
After my shower, I would dump that water out, or use it to wash my Easy Care boots and tack. Recycle and conserve my water.
Posted 2009-09-09 10:30 AM (#110479 - in reply to #110462)
I'm about to do the same thing.  I went looking for a Kiddie pool...   Darn, they're all sold out though out the town... Season item you know ...
IcePonyGoddess
Reg. Nov 2006
Posted 2009-09-09 11:01 AM (#110481 - in reply to #110479)
500100100252525
Weather you use a muck bucket or a kiddie pool, make sure you also use one of those non-slip mats, so you don't slip & fall. As the containers can and do get slippery.
Bells
Reg. Jun 2007
Posted 2009-09-10 10:48 AM (#110541 - in reply to #110462)
I have one of these:
It has a hose connect (you can see it on the bottom left in the picture not being used) so you can drain it.  The local Tuesday Mornings had them for about 20$.  I still see them there when I drop in so they weren't big sellers.
perk2754
Reg. Oct 2007
Posted 2009-09-10 1:27 PM (#110558 - in reply to #110462)
Thanks for the input!
Ice, I don't think I would fit in a muck bucket and if I did I would probably trip coming out, lol
Bells, did the cute Cocker come with it?
Bells
Reg. Jun 2007
Posted 2009-09-10 4:47 PM (#110567 - in reply to #110462)
*Snort*  No, just a picture I pulled off the internet.
terri s
Posted 2009-09-11 9:14 AM (#110578 - in reply to #110462)
500100100100
I looked at those in one of my catalogs and thought they looked perfect until I saw 99.99. I will have to see if I can find a Tuesday Mornings-thanks for the idea!
Rose66
Reg. Dec 2006
Posted 2009-10-25 12:34 AM (#112349 - in reply to #110541)
Bells, does a regular water hose screw onto the water drain plug of your dirty dog bath? I can't find any definite yes or no answer on the internet and every picture I've found just shows the water draining out on the ground right where the unit is sitting. Thanks!
terri s
Posted 2009-10-25 7:54 AM (#112352 - in reply to #110462)
500100100100
Something I will do "someday" in my shower is run the drain hose into a tank on wheels-they make them for RVs and you can get them as small as 25 gallons. You just roll the tank where you want to drain and empty it. Not every place I will be with my trailer is a good place to run water out on the ground, so...thought that might work.
KeepsakeFarm
Reg. Feb 2008
Posted 2009-11-04 6:40 PM (#112805 - in reply to #110462)
WE got a square plastic washing machine drain pan and attached a water hose connector.  I carry hoses so we just attach a hose and drain it someplace where the resulting mud doesn't cause any trouble.
tucson
Reg. Dec 2009
Posted 2009-12-31 1:21 PM (#114705 - in reply to #110462)
I just put a shower in our first stall this spring. We used a smaller black rubber stock tank the sides are about 12'' high so water doesn't splash out under the curtain. I used 4 pcs. of small pvc and ran nylon cord through it to make a 2 1/2' square so it can be taken down and folded up if you need to use the stall. I found these great spring hooks at menards to hang the pvc from and they spring back flat against the side whe nnot in use. I installed a regular metal sink drain to it and drilled a 1 1/4 hole through the floor to drain it and used a 3" hole saw to cut through the rubber mat. Then the rubber disk can be put back in if you remove the tank to haul something in the stall.  It works GREAT!
I also made a small pallet using the decking material to stand on so when you get out you can stand on that up off he floor.
Edited by tucson 2009-12-31 2:35 PM
tucson
Reg. Dec 2009
Posted 2009-12-31 2:28 PM (#114707 - in reply to #110462)
We used a black rubber stock tank that was oval and about 12" tall that way the curtain stays inside and water doesn't spash out the sides. I put a regular metal sink drain in it and used a 1 1/4'  for the drain pipe to run out through the floor. The mat I used a 3" hole saw to drill through and then can replace the rubber disk if you need to use the stall so shavings dont get all stuck in there.
Jean F.
Reg. Jul 2005
Posted 2010-01-18 12:18 AM (#115404 - in reply to #110541)
That folding pet tub caught my attention.  I came across one in December at Harbor Freight Tools, on clearance.  I bought it for $8.00.  All I have to use it with is a solar shower.
We will see if it gets used this season...
figero
Reg. Oct 2004
Posted 2010-01-18 8:23 AM (#115409 - in reply to #110462)
If you have a wood floor in your trailer just roll back the rubber mat and let the water flow between the boards
tucson
Reg. Dec 2009
Posted 2010-03-07 8:46 PM (#117326 - in reply to #110462)
I would go with a 12" tall black stock tank about 20gal. or so and attach a regular drain onto it and drill a matching hole in the floor. It works great!
