       Location: western PA | The combined weight of most GN trailers will overwhelm a F150 pretty quickly, regardless of tire sizing. Depending on the front profile of the trailer, your friend may have interference difficulties with the truck's rear window. A broad flat nose may pose a problem, while a tapered or sharply rounded one may not. The width of the trailer will also make a difference, with the narrower ones being generally, less problematic. Each trailer manufacturer builds his equipment slightly different than the others. It's not possible to say that because XYZ trailers fit, all the others will as well. Hitch extenders are an option to help alleviate the interference problems. They have been previously discussed here: http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=11923 BOL Gard |
