  Location: NM | I have an 1993 Featherlite w/the smaller windows like this (hopefully the picture will post - if not 5th item down on this page: http://www.horsetraileraccessorystore.com/window_feed_doors.htm) | Drop-Down Windows serve as "feed-door" and window combined! Top-latch handle opens from outside, hinged at bottom. "T-slider" style lower glass panel allows screened ventilation with window in upright-closed position. | I would like to add some drop down bars to so that the horses can have some more air flow. I've done several searches and can't find a source for them. Anyone have some handy links or maybe a better search term than what I have been using? |
      Location: Rocky Mount N.C. | I would contact Featherlite first, see if they could help, give them the serial number, they should be able to "match something"... Here's some other drop down windows... http://www.statewidealum.com/livestock-trailers-statewide-alum.htm http://www.hehr-international.com/0280feederwindow.htm |
  Location: NM | Thanks Retento - I was hoping to not have to replace the whole window but just find something that could be added on. I'll contact featherlite but do you think that there might be a way to just add on the bars to the inside of the window? |
       Location: western PA | A few years ago we purchased a used trailer that had window mounted bars. One window's bars were badly bent, a second was slightly damaged. I took them both to a welder, who easily fixed the one that was less damaged. He determined that it would be easier to fabricate a new one, than rebuild the bent and broken assembly. I picked up some materials, cut them to length and dropped them off. In less than 1/2 an hour he had the new one built. Total cost for his labour was $35 for both. If you know a welder, he should be able to custom make some bars for your windows. The fixed ones are much easier to fabricate than the drop down type. You might also consider using stainless materials instead of aluminum. Gard |
    Location: MT | I had a 96 featherlite that had the same thing and I purchased these. http://www.nrsworld.com/istar.asp?a=6&id=HA-600!PRCHO Cheap and easy worked good. Horse got air and couldn't stick its head out to get taken off by truck, or get a bug in the eye. |
  Location: NM | Brew - how long did they last? Did you have any trouble w/horses pushing through them? |
    Location: MT | I think they lasted a around 5-6 years I think. They did push on them a little but they held up good for what they cost.
Edited by brew26 2009-07-28 2:36 PM
       Location: western PA | We put screens in one of our trailers two years ago. They do hold up and work well. Be sure to get the zippered type. Gard |
Location: Michigan | My brother's trailer came with those Professionals Choice ones in it. They have elastic loops in the corners and they stretch out really easily. We opted to replace them with this style of Professionals Choice ones with the velcro closures: http://shop.hawthornecountrystore.com/browse.cfm/shop-by-brand/professionals-choice/professionals-choice-trailer-window-screen/4,3024.html?AFF=BASE We've had them in all summer and hauled almost every other day, they're still going strong. Our horses only lightly touch them with their noses, but haven't caused any damage. They're also easy to undo with the velcro closures. |
