wiring - changing 4 pin to 7
mscris
Reg. Jun 2009
Posted 2009-06-26 11:25 PM (#107123)
Subject: wiring - changing 4 pin to 7
I have the electronic brake, from my old truck. However the convertor stayed attached to the bumper of the truck when it was traded.  My question : should I hard wire the new 7 pin connector or can I purchase the kind that plugs into the 4 pin (with hardwire ground and battery) to be able to use the 4 pin if I ever need it.
I've only have just started seeing the 9 into 4 convertors like the one at the bottom of the link i've attached
http://www.go-rv.com/coast/do/catalog/page?pagePrev=TRUE&dealerId=320&pageNum=506
What I'll be towing - motorcycles, horses either way i'll be in the gross towing weight of an expedition
Posted 2009-06-27 1:02 AM (#107127 - in reply to #107123)
Subject: RE: wiring - changing 4 pin to 7
As I understand your post , your vehicle has a 4 pin flat Plug.  You need the 7 pin round Plug for brakes and aux power circuit.
If you purchase the 7 /4 pin connector as in the link, It comes with a 4 pin flat plus bare wires for the brakes and power.  You'll have to disconnect its flat plug to use 4 pin flat plug trailers.  Sounds terribly inconvenient.
I would hard wire the new 7 pin connector.  Change all the trailer plugs to 7 pin and only use 4 if the trailer doesn't have brakes.
Posted 2009-06-27 3:23 AM (#107129 - in reply to #107123)
http://www.horsetrailerworld.com/home/wiring.asp
mscris
Reg. Jun 2009
Posted 2009-06-27 5:44 PM (#107165 - in reply to #107127)
Yes, you understand my question.  Since I know nothing about hardwiring, I 'll drop off the truck to my mechanic and have him do it.  I am thinking if I purchase the kit, it should not be much of a cost.  -or- do you think it is the same quality of work if I take it to the Uhaul dealer and have him install it and purchase the wire harness there.
MSM
Reg. Jun 2009
Posted 2009-06-28 9:47 AM (#107182 - in reply to #107123)
As the experts have stated, your better of to hardwire a new plug in.  It will make your life alot easier and will justify the means..............!!!!!!!!!!!!!!!
