tankless water heaters
sidelock
Posted 2009-06-13 10:28 AM (#106400)
Subject: tankless water heaters
A while back there was some discussion about tankless water heaters but after doing a search I could not find the information I am looking for.
I'm trying to weigh the pros and cons between a conventional LP RV water heater and and an LP tankless unit.
If an LP tankless is installed in the first stall much like a cowboy shower , would the butt window provide enough ventilation for these " outdoor use only " units ?
Also can they be retrofitted with some kind of adaptor where the shower hose is attached to supply hot water to the sink ?
wyndancer
Reg. Apr 2007
Posted 2009-06-13 11:56 AM (#106402 - in reply to #106400)
Subject: RE: tankless water heaters
I have seen a LP tankless that resembles a 12 gallon RV unit in size. It's vented the same as well.
Whinny2
Posted 2009-06-13 12:19 PM (#106403 - in reply to #106402)
Go to www.houseneeds.com click on water heaters then click on rv-500 very expensive.
sidelock
Posted 2009-06-13 12:31 PM (#106404 - in reply to #106400)
Marey LPG 5L, 19"x11.5"x4.5" , 12 lbs. On ebay @ $195. I belive Camping World has a unit for under $150.
Edited by sidelock 2009-06-13 12:33 PM
