truck wheels on trailer ?
jarmstrong
Reg. Mar 2009
Posted 2009-05-28 1:03 PM (#105635)
Subject: truck wheels on trailer ?
has anyone ever used truck wheels on their horse trailer or is the backspacing way different ? I ended up with a set of chevrolet truck wheels that are 6 lug and look to be the same as our trailer and they are nicer looking wheels so I was wondering if they would work? thanks
                                                              Jerry
brew26
Reg. May 2009
Posted 2009-05-28 3:00 PM (#105641 - in reply to #105635)
Subject: RE: truck wheels on trailer ?
I used my spare tire for my pickup on my trailer once worked pretty good.
Posted 2009-05-28 3:49 PM (#105642 - in reply to #105635)
If they fit, they should work. If they are aluminum "mags", you probably will need a different set of lug nuts. Do not use a tapered lug nut on a shouldered application.
jarmstrong
Reg. Mar 2009
Posted 2009-05-28 4:24 PM (#105645 - in reply to #105635)
I also wanted to try these since they are 16" and it seems easier to come by the heavier load rating tires in a 16.Right now I have 10k lbs of tire rating wich is enough but the trailer is actually the trailer is rated for 12k.Right now we only carry my wifes trail horse and camping gear but hope to add a horse for me soon.thanks for the help.
                                                 Jerry
headhunter
Reg. Oct 2004
Posted 2009-05-31 12:47 AM (#105741 - in reply to #105635)
50010010025
Check to be sure they have enough weight capacity and/or air pressure rating for the tires you run on your trailer.
301duster
Reg. Jan 2009
Posted 2009-05-31 6:42 PM (#105766 - in reply to #105635)
Yeah, I've run pickup (?Ford?) 8 bolts on my trailer.  They worked better than the chrome "spokes" someone had put on it.  Didn't stick out as far. Actually still run them on a flatbed I built.  Works fine!!!
Posted 2009-05-31 7:38 PM (#105767 - in reply to #105635)
Here's some GM pickup truck wheels dressing up an old Bison...
image 1197415581-0image 1197415581-1
image 1197415581-2image 1197415581-3
