Inside trailer lights not working
memory
Reg. Jul 2007
Posted 2009-05-27 10:59 PM (#105586)
Subject: Inside trailer lights not working
My lights work on the outside of the trailer, but the inside of the trailer don't. They worked fine last fall. Where do I start checking?
Posted 2009-05-27 11:06 PM (#105587 - in reply to #105586)
Subject: RE: Inside trailer lights not working
Start at the beginning... aka the power source.  Trailer Battery or truck?
brew26
Reg. May 2009
Posted 2009-05-28 8:51 AM (#105608 - in reply to #105586)
Its not power source because your outside lights work. Does your inside lights have a switch somewhere that isn't working. I'd start from your lights on the inside and work back usually it goes faster doing that.
Tresvolte
Reg. Feb 2008
Posted 2009-05-28 8:58 AM (#105611 - in reply to #105586)
When you say your outside lights are working, do you mean your outside load lights, or your running lights?
If your outside load lights are working start at the swith for the inisde lights and make sure you have power there, then wokr whichever way you need to from the switch.
memory
Reg. Jul 2007
Posted 2009-05-28 9:39 AM (#105617 - in reply to #105586)
The outside running lights work but not the interior loading lights. I will start at the switch for the interior lights. Thanks
RTSmith
Posted 2009-05-28 12:04 PM (#105633 - in reply to #105586)
I'm with Hosspuller on this one. Check the truck. The white lights are a different circuit. In all liklihood you have blown a fuse.
RTSmith
jim bob
Reg. Jan 2008
Posted 2009-05-28 12:07 PM (#105634 - in reply to #105586)
Your inside lights usually work off an auxiliary wire or hot wire from your truck.  I would first check your fuse box under your hood or the panel below the dash.  I bet either you have a blown fuse, or you have the hot or auxiliary wire that has come loose in your truck plug.
