Lug nut torque
Donkeymansteve
Reg. Apr 2009
Posted 2009-05-27 3:40 PM (#105553)
Subject: Lug nut torque
I just re-packed the wheel bearings on my 3 horse steel GN but I'm not sure what to torque the lug nuts to. These are 8 lug steel wheels. Any suggestions? Thanks.
brew26
Reg. May 2009
Posted 2009-05-27 3:52 PM (#105556 - in reply to #105553)
Subject: RE: Lug nut torque
Do you  have a raquet that you can set to certain torque or you just going to guess. When I did mine I treated them just like they were a pickup tire.  Go until you can't turn them with your raquet by hand.
Posted 2009-05-27 3:54 PM (#105557 - in reply to #105553)
My Haynes manual for the Chevy truck says for 8 lug wheels 9/16 bolts ... 118 foot-pounds
Posted 2009-05-27 3:56 PM (#105558 - in reply to #105553)
Depends on if they are 1/2" or 9/16"....
Hardware Bolt or
Stud Size - Typical Torque Range
in Ft/Lbs - Minimum Number of Turns
of Hardware Engagement
12 x 1.5 mm 70 - 80 6.5
12 x 1.25 mm 70 - 80 8
14 x 1.5 mm 85 - 90 7.5
14 x 1.25 mm 85 - 90 9
7/16 in. 70 - 80 9
1/2 in. 75 - 85 8
9/16 in. 135 - 145 8
Tresvolte
Reg. Feb 2008
Posted 2009-05-27 4:12 PM (#105562 - in reply to #105558)
Dexter Axles calls for 90-120 lbs on 15" and 16" wheels. The maximums are 120 lbs on 1/2" and 170 lbs on 9/16".
Donkeymansteve
Reg. Apr 2009
Posted 2009-05-27 4:16 PM (#105563 - in reply to #105553)
Thanks for all the replies. I have them at 100 ft/lbs now so maybe I'll add 10 or 20 more to be safe.
Posted 2009-05-27 4:34 PM (#105566 - in reply to #105563)
Originally written by Donkeymansteve on 2009-05-27 1:16 PM
You didn't say what diameter the bolts are... It'll be safer to keep them at 100 ftlbs and drive for a few miles.  Then recheck them.  It's darned hard to change a tire when the lug nuts are too tight and have been that way for years.
Edited by hosspuller 2009-05-27 4:35 PM
Donkeymansteve
Reg. Apr 2009
Posted 2009-05-27 4:52 PM (#105568 - in reply to #105553)
They are 9/16". I'll drive it around a few miles and re-torque, as suggested.
Barfly
Reg. Jun 2008
Posted 2009-05-28 1:39 AM (#105591 - in reply to #105553)
Turn them till they stripp, then back them off by half a turn....lol
Jokes guys
Tresvolte
Reg. Feb 2008
Posted 2009-05-28 7:17 AM (#105598 - in reply to #105591)
Originally written by Barfly on 2009-05-28 1:39 AM
Jokes guys
That's what I do, I just wasn't going to recommend it to someone else...
Posted 2009-05-28 9:14 AM (#105613 - in reply to #105553)
If you are actually using a torque wrench for the proper application, you might want to consider the usage of oil or grease on the threads before the nuts are tightened. A "wet" torque will give you a more accurate reading. Another advantage is when you have to remove the nuts, they won't be rusted to the studs.
Edited by gard 2009-05-28 9:51 AM
Donkeymansteve
Reg. Apr 2009
Posted 2009-05-28 10:49 AM (#105623 - in reply to #105553)
I did use a little anti-seize compound on them before tightening.
Posted 2009-05-28 10:55 AM (#105624 - in reply to #105553)
Even better. Good job
